06-05-2014, 08:52 PM | #1 |
"Precious" 2011 SS/RS
Drives: 2011 SS/RS, f1X procharger, LSX427 Join Date: Apr 2013
TVS2300 belt slip- what's the best tensioner, extra rib setup?
Just added a cam and head work to my setup, while tuning, the boost goes away at higher rpms. Def have a belt slip problem-What is the best setup for the front side of the engine (I have the jackshaft). I have already installed the cog setup on the back.
06-05-2014, 09:06 PM | #2 |
Adm performance has a brand new hd tensioner and idler combo. Give andy a call and see what kind of deal he can give you.
06-05-2014, 09:28 PM | #3 |
Thanks
06-05-2014, 09:52 PM | #4 |
Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
Definitely try the tensioner. The 8 rib setups are pretty high unless you really need them.
06-05-2014, 10:03 PM | #5 |
Drives: 2011 2SS Join Date: Jun 2013
Curious to know more about the adm tensioner setup and pricing anyone have any links about this
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
06-05-2014, 10:39 PM | #6 |
Drives: 2010 Inferno Orange Join Date: Dec 2012
I have the same problem. I added a Jannetey super tensioner and it didn't fix the problem. I ran 8 lbs of boost before tensioner and after, so I decided to go with a 8 rib system. Jannetey set me up with the 8 rib. Definitely not the cheapest setup to go to the 8 rib but I want more boost.
06-06-2014, 06:50 AM | #7 |
I forgot to mention I also added an e85 kit at the same time and that added a lot more power so I guess I'm not sure what the tensioner would have done at equal power.
06-06-2014, 09:29 AM | #8 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
When you overdrive the rear you add speed to the rotors which make them HEAVIER to the belt and increases the chance for belt slip..The 8 rib is a much needed piece .We have a great tension setup and can get you a great price on the whole 8 rib setup..Give me a call if I can help you out
06-06-2014, 04:08 PM | #9 | |
06-06-2014, 09:00 PM | #10 |
Adm r u out there somewhere didn't see anything on the website
06-07-2014, 09:47 AM | #11 |
Drives: Anything I want Join Date: Oct 2008
Here is our tensioner with optional lower idler that's helps stay tight to the crank
06-07-2014, 09:50 AM | #12 |
Here is another view
06-07-2014, 02:01 PM | #13 |
One Slow Automatic
Drives: 2017 GS 2010 CAMARO SS Join Date: Mar 2010
ADM, besides the bracket being black; is there any difference between JRE super tensioner and your super tensioner?
650HP 2010 CAMARO SS 710HP 2017 GRAND SPORT
06-07-2014, 02:43 PM | #14 | |
