07-10-2017, 05:49 AM | #1 |
Interchiller
Anyone have experience with or real world results using an interchiller on a PD blower? Looking to get my IAT's down some more and I figure if the factory Demon has one they must be pretty effective.
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
07-10-2017, 11:32 AM | #2 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
You can go to fiinterchiller.com and read all of the real world results you want.
07-10-2017, 12:50 PM | #3 |
Drives: Red Jewel Camaro SS Join Date: Mar 2014
We did 2 this summer so far. Just finished a ZR1 this morning.
Just did a 10 minute drive with the chiller on. About 2 hours later,did the same drive with the chiller off (normal intercooler only). I see 45-50F difference on the datalogger.Normal driving with 2 3rd gear pulls.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
07-10-2017, 02:49 PM | #4 | |
Drives: 05 GTO / JETTA TDI Join Date: Jan 2012
We invented the Interchiller brand and system in 09 which includes the Competition Mode everyone has copied, automatic H/E bypass and progressive Freon Distribution on inlet of core for even distribution. We have the only complete kits with single switch wiring harness, LED, no drill switch mount, no AC hoses added under hood; only 2 AC hoses added behind bumper, 100% no cut bolt on ZL1 kit, new high flow coolant fittings and new CNC temperature sender. We started selling Camaro kits in 2011 and have testimonials on this forum going back to 2012 in Vendor Section. |
07-10-2017, 07:10 PM | #5 | |
With this kit where does the condensate go other than the ground where the track would kick you off for leaking water on the track thanks in advance
07-10-2017, 07:51 PM | #6 | |
07-10-2017, 08:01 PM | #7 |
Should have come from the factory like this on a PD blower setup...what's the install like, I do 99% of the work myself when time permits...I'm tired of going to the track a sitting after a run for a while or sitting in the lanes idling heating for my turn. I also like the factory look too
07-11-2017, 07:04 AM | #8 | |
07-11-2017, 11:20 AM | #9 |
Flip of the switch and all Freon goes through the interchiller only for the best cooling and nothing on the track, I've seen temps as low as 36 degrees on a 85 degree day with a TVS2300, all of the different chillers work well, it's just comes down to who actually has them for sell.
07-12-2017, 05:10 AM | #10 | |
Sounds like a winner here, my biggest thing is no splicing or cutting while keeping the plumbing and wiring looking as factory as possible while what you paid for does the job it's supposed to do
07-14-2017, 11:47 AM | #11 |
No splicing, they come with all of the lines, connectors and fittings to bolt in and go back to stock if you want later, I think the killer chiller is the only one that you have to cut up all of your factory lines to install, I wouldn't recommend that one.
