Old 01-14-2017, 07:39 PM   #1
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Toe specs keep changing
Hey guys I'm needing help. I've done taken it to get alignment done twice and both times it moves out of spec. Under hard throttle the cars rear end feels like it's steering. Mods are Lakewood adjustable toe rods, trailing arms and cradle bushings. Everything was good until I added the cradle bushings but I'm not putting the blame on those. Could it be that now with the bushings everything is being worked harder? I can get on it at half throttle and it's ok but when I go full throttle that's when I'm having the issue. I'm at 600+ whp. Any help would be great.
camarosspower is offline   Reply With Quote
Old 01-14-2017, 09:45 PM   #2
Abdi
Drives: 2013 1LE
Which brand of bushings did you put in? Are the toe rods somehow coming loose?
What toe setting is the alignment shop using for you? I would double check and make sure it is toe IN and not toe out. Toe out would definitely give you that rear steer feeling.
Abdi is offline   Reply With Quote
Old 01-14-2017, 10:07 PM   #3
camarosspower
Toe in was set at .05 but it changes after I go full throttle
Old 01-15-2017, 08:38 PM   #4
camarosspower
This I what I got when they done the alignment
Old 01-15-2017, 08:40 PM   #5
camarosspower
This is how much it changed when I went back. Before they adjusted it once again.
Old 01-15-2017, 08:42 PM   #6
JOHNSONROD
JOHNSONROD's Avatar
Drives: 62 Chevy & 2021 1SS/1LE manual
do you still have FE3 rear anti sway bar? if so, you need to do the upgrade to FE4 before you will know. the FE3 suspension is absolute crap junk. you cannot make it work right. with extra HP like you have, its just going to walk worse.
JOHNSONROD is offline   Reply With Quote
Old 01-15-2017, 08:44 PM   #7
camarosspower
This is what I left with but I'm pretty sure it moved again. The car is extremely slippery at full throttle
Old 01-15-2017, 11:47 PM   #8
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Are they adjusting the camber and toe at the same time? The rear specs of these cars have to be adjusted together otherwise they can change.
More to come.
Black_SS10 is offline   Reply With Quote
Old 01-16-2017, 05:05 AM   #9
camarosspower
Well the guy didn't even mess with the camber because he said it was maxed out already.
Old 01-16-2017, 05:08 AM   #10
camarosspower
Do you think this is the reason behind why the toe changes?
Old 01-16-2017, 07:52 AM   #11
Synner
Drives: cars
Sway bars don't change toe. You have loose bolts somewhere or an out of spec bushings allowing things to move. Neither one can be diagnosed over the internet.
Old 01-16-2017, 08:10 AM   #12
camarosspower
Just asking for suggestions on what would change toe. If anything else besides the toe rods
Old 01-16-2017, 08:21 AM   #13
Synner
Drives: cars
Cradle bushings and toe rod bushings and bolts are where I'd start. The cradle can shift so don't rule them out until you've physically confirmed they're ruled out. Especially since that's the last thing you changed and now you have the issue. What torque specs did you or the shop use? What brand bushings? BMR sold the wrong size bushings or they deformed to a few people that caused this as well.
Old 01-16-2017, 09:07 AM   #14
camarosspower
I didn't torque them but I did tightend them up real good. They sitting flush with the cradle. I did notice that I don't have the D shaped thread bolts on the toe rods. They look like offset washers
