12-16-2011, 03:11 PM | #1 |
Drives: 2010 Camaro SS Join Date: May 2009
(Day 5) - The Twelve Days of Christmas Technical Posts - a New Product Everyday!!
CAMARO POST
Commercial Thread Here: http://www.camaro5.com/forums/showth...01#post4176801 (Day 5) - The Twelve Days of Christmas Techinical Posts - a New Product Everyday!! Merry Christmas!!! MTI Racing is highlighting a new product each day to show you the benefits and features of some great products on the marketplace. "On the Fifth day of Christmas, my true love gave to me..." Today’s demonstration for Friday Dec 16th is… Check out this Video: 1) Corvette Lowering (C5/C6/C6Z) 2) Brembo Sport Rotors for Camaro (5th Gen V8) CHECK OUT THIS PRODUCT INFO: Brembo Sport Rotors for Camaro http://www.mtiracing.com/Purchase/Ne...r-Upgrade.html BREMBO SPORT ROTOR UPGRADE PACKAGE FOR 2010+ CAMARO V8 These rotors are direct replacement and available either slotted or cross drilled. Your Camaro has Brembo calipers with GM rotors. Direct replacement Brembo Sport brake rotors are for drivers who want to improve the performance and looks of their vehicle’s original braking system without having to change additional brake components. Brembo Sport slotted brake rotors provide excellent stopping power in everyday traffic, as well as high performance street and track driving. Brembo Sport brake rotors match the vehicle’s Original Equipment rotor’s dimensions and are fully compatible with its hubs, brake calipers and road wheels. Front and rear Brembo Sport brake rotors are available to provide a matched appearance on all four corners of the vehicle, and employ one-piece vented or solid rotors depending on the vehicle’s Original Equipment specifications. Starting with select castings, Brembo Sport brake rotors undergo the race-born practice of machining multiple shallow slots into the disc’s front and rear surfaces to provide paths to disperse built-up heat and gasses and assist in refreshing the surface of the brake pads. The slots are angled to use the rotors’ direction of rotation to enhance their performance, which makes the rotors side-specific with left and right side rotors. Brembo Sport slotted brake rotors are sold in axle pairs and the easiest way to verify correct usage is to install the rotors on the side of the vehicle that results in the end of the slot nearest the outer edge of the rotor always contacting the brake pads first. The Brembo Sport drilled brake rotors undergo the race-born practice of cross drilling to provide multiple paths to disperse built-up heat and gasses. The Brembo Sport rotor’s cross-drilled holes are bi-angle chamfered at the rotor’s outer surfaces to help reduce the cracking caused by repeated, high stress, high temperature brake applications. Brembo Sport drilled brake rotors are sold in axle pairs. Brembo Sport brake rotors are coated for corrosion resistance to help eliminate rust and offer a bold, aggressive appearance to enhance the look of the vehicle’s road wheels. Brembo Sport slotted brake rotors are designed to meet the challenges of high performance street driving while adding an authentic, race-ready look. NOTE: Brembo Sport slotted brake rotors can be used in conjunction with race compound brake pads on the track for drivers’ schools and lapping days. Corvette Lowering Bolts: http://www.mtiracing.com/Purchase/20...-Corvette.html Lowering Bolts for Corvette Check out this lowering kit from MTI Racing for C5 and C6 Corvettes. This kit contains all the necessary hardware to lower the stance of your C5/C6 for a more aggressive look. You can drop the car up to 2" lower than stock. Not only do you get a more aggressive look, you also lower the center of gravity to improve your cars handling, and maintain a comfortable ride. Can be installed using simple tools and a entry-level mechanic. (it just takes a long time) C5 Kit: -Includes 2 Black bolts with Pads and 2 Long Bolts with Urethane Bushings C6 Kit: -Includes 4 Black bolts with Pads. (also fits C6 Z06) For more information, please visit this commercial thread HERE: http://www.camaro5.com/forums/showth...01#post4176801 p.s. *If you happened to eat too much Holiday Fruitcake and missed today’s info, check out our Facebook page. Merry Christmas!! |
Similar Threads | ||||
PWA "The Lounge" | DGthe3 | Off-topic Discussions | 143773 | 11-06-2010 11:00 AM |
5th Gen Christmas Dollar Days!! | Info@PeddersUSA.com | Suspension / Chassis / Brakes | 36 | 12-20-2009 12:01 PM |
2010's Sold Out ! | carguy | 5th Gen Camaro SS LS LT General Discussions | 53 | 12-06-2009 01:12 PM |
IMPORTANT Part 1 Warranty Disputes | Zeus | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 11 | 08-25-2009 11:37 AM |
Pedders December Dollar Days for the 2010 Camaro and Brand X Vehicles | JusticePete | Wheels and Tires Talk Sponsored by The Tire Rack | 85 | 07-26-2009 05:20 PM |
