02-01-2012, 05:31 PM | #1 |
Drives: 2010 2SS/RS M6 Join Date: Oct 2010
Royal Purple Transmission and Rear Differential Fluids
Is Royal Purple 75W90 SynchroMax the best product from the Royal Purple product line to use for the Transmission and Rear Differential fluids on a 2010 SS Manual LS3?
Build Journal
http://www.camaro5.com/forums/showthread.php?t=332853 Magnuson TVS2300 with 3.4" Pulley, 1:1 Cog Drive, and RDS Spacer 2" Stainless Works Headers / Cat Delete / 3" Stainless Works Retro Chambered Catback Cold Air Inductions Intake with ADM Scoop ID 850 ZL1 Fuel Pump ADM FPCM VMAX Ported Throttle Body DSS 1 Piece Aluminum Driveshaft JRE 93 Octane Tuned |
02-01-2012, 07:40 PM | #2 |
Retired Navy
Drives: 2010 2SS/RS Join Date: Mar 2011
Rear end yes, manual tranny no. You want Max ATF for the Tranny.
Retired Navy... A Husband. A Dad. A Veteran as of 2011. 2010 2SS/RS A6 - FlowMaster CatBack - I'm not a Amsoil dealer and will never be one. I believe in its capabilities from personal use with oil analysis reports backing up my OCI's. Besides, I know more than most cut and paste Amsoil dealers which are at least 95% of them.
02-02-2012, 04:58 PM | #3 | |
MIC
Drives: 2012 SSRS 6sp man Blk Join Date: Nov 2009
SS Camaro LS3 M6 Royal Purple Products;Manual Trans = Synchromax 4 qts. Limited slip Rear= MaxGear 75/90 1 qt. no adder Go Navy Just trin to help 1967 USS Forrestal |
02-02-2012, 05:15 PM | #4 |
Retired Navy
It's all good. Dex III is what is supposed to be used in the Tremec though.
02-02-2012, 06:59 PM | #5 |
MIC
02-02-2012, 08:02 PM | #6 | |
Retired Navy
I'm not a shellback. I was a TAR/FTS my whole career. I did a five month Med cruise on the Roosevelt in 03. The farthest south we made it was Puerto Rico for work ups. Our Hornet squadron (VFA-201) got activated and we recalled all of our reservists.
02-03-2012, 10:41 AM | #7 | |
MIC
Royal Purple Tech Info
2010-2012 SS Camaro Auto Trans - RP Max ATF Part #01320 Manual 6sd Trans. - RP Synchromax Part #01512 Differential - Max Gear 75W-90 part #01300 NO additional limited slip friction modifier needed. So you were a airdale - Tough job Hats off to you brother I was on the USS Forrestal from Jan. 1967 to Dec. 1968. Vietnam and Med and couple trips to Gitmo My 21st birthday on a rock with beer on the beach at Gitmo Last edited by MIKnam67; 02-03-2012 at 10:51 AM. |
02-18-2012, 08:28 AM | #8 |
Bevo
Drives: 2010 2SS/RS Join Date: Jul 2011
having grind from 1-2 with Hurst short throw. Replacing fluid with RP this week to HOPEFULLY fix the problem. Several users on here have said that it has really helped out. I'm holding my breath
02-18-2012, 09:09 AM | #9 |
MIC
02-22-2012, 06:05 PM | #10 |
So easy to love Camaros
Me too, please post the results. Maybe doing that real soon too. I can't help but wonder if someone on a test drive, forced a 2nd throw when the 1-4 shift came on. I installed the skipshift already.
02-22-2012, 06:28 PM | #11 |
Drives: 19 Z06 Join Date: Nov 2011
Good point
Gone but not forgotten:
1974 Corvette Stingray 454 1986 Z28 2009 Mustang GT convertible 2012 45th 2SS Vert 2013 ZL1 M6 2014 Zl1 M6 2014 GT500 2016 Challenger Hellcat M6 www.youtube.com/c/garageking |
02-23-2012, 08:56 AM | #12 |
AMC Reject
Drives: 45th Anniversary Join Date: Dec 2011
I was going to change to RP in the tranny and the diff.
Does anyone know how much I need to change out the fluids in a M6 2SS? |
02-23-2012, 11:47 AM | #13 | |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
If you get a little hand gear lube pump from the auto parts store, that make it easier to fill the trans. |
02-23-2012, 03:36 PM | #14 | |
AMC Reject
Similar Threads | ||||
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
