09-26-2020, 07:36 AM | #1 |
Drives: 2013 HWSE Indy Festial #26 Join Date: Mar 2011
Price check on OEM Mag Ride
I am looking at Summit Racing to price out a new set of AC Delco mag rides as my winter project. My ZL1 has 40K miles and will (hopefully) see a lot of track time next year. Only 4 track days this year because of stupid covid.
Front left 471 Front right 463 Rear left 383 Real right 411 Total is approximately 1730 Is there a cheaper source that I'm missing? I want these new with lifetime warranty so I don't have to do this job again on this car.
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan Last edited by Z/28Dan; 10-03-2020 at 07:12 AM. |
09-26-2020, 09:08 AM | #2 |
Shred Till I'm Dead
Drives: 2013 ZL1 Summit White Join Date: Aug 2016
I got mine at Rock Auto. I don't remember the exact price but they were cheaper than Summit at the time.
2013 Summit White ZL1 W/Recaros
Mods: Roto-Fab CAI, Stainless Works 3" Exhaust, 1-7/8" Stainless Works LT Headers, 2.55 Griptec Upper, Metco Damper, 9.1" Metco Lower Ring, Metco Solid Isolator, Metco Idler Relocation Bracket/50mm Idler, Texas Speed Heads/Pushrods/Springs/Retainers/SS Valves/Custom Grind Cam, ARP Bolt Kit, DMS Auxiliary Fuel Pump Kit With Flex Fuel Sensor, ID1300 Injectors, Lingenfelter Dual Fan HX, Lingenfelter 160 Degree Thermostat, DMS Expansion Tank Tuned By Matt at Dedicated Motorsports - 750whp on E85 - Mainline Hub Dyno |
09-26-2020, 11:23 AM | #3 |
Rock Auto prices are about the same on the rears, but 70 bucks lower on the fronts. Good find!
Dan |
09-26-2020, 11:25 PM | #4 |
2013 ZL1
Drives: 2013 ZL1 m6 Join Date: Oct 2010
Current amazon price for ACDelco 580-428 is $338.45. Showing out of stock.
ACDelco 580-445 GM Original Equipment Rear Shock Absorber Kit $382.99 ACDelco 580-429 GM Original Equipment Front Passenger Side $464.36 Thse part numbers are for the coupe. I keep them in my saved for later to buy at lowest price. Picked up one of the fronts for about 275 and the rears for 350 doing this. I needed the rears, but my original fronts are still good. Waiting for price to drop on the other before i get it or when they fail. |
09-27-2020, 08:10 AM | #5 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
10-03-2020, 06:57 AM | #6 |
Good advice. I put a price tracker on Amazon. Hopefully I can score a deal in the next few weeks.
Thanks!
Dan |
