05-01-2016, 05:31 PM | #1 |
Looking for ideas, advice, and help please
so i'v had my 2010 Camaro LS with 16,000 miles a little over a month now it has aftermarket exhaust the solo mach x set up and K&N cold air intake which came on the car when purchased. About a week after getting the car from the dealership i started to notice a whistling sound only between 2-3000 rpms and only while in drive it will not do it in park, or neutral. and only does it while accelerating between the 2-3000 rpm if i hold the pedal between those rpms it will last for as long as i hold it as soon as i let off it goes away until i accelerate back to that point again. i think i didn't hear it when i test drove it because i was full of excitement and had the radio and climate control etc going on. i'v searched and searched for any ideas but no luck. i even had it at the dealership and they said that it is nothing to worry about since there is no loss in power or CEL on. since it is a 2010 the factory warranty is over and the 30 day dealer warranty is over now also. it only drives me crazy when i have the radio off but it seems like it hasn't gotten any worse and i have checked all connections and screws on the K&N and snugged up the throttle body as well as gave each bolt on the intake manifold about a quarter to half turn thinking maybe a vacuum leak somewhere but its strange only hearing it as described above since it does not do it any other time. i have had K&N CAI on other vehicles in the past and never had one whistle before so i'm kinda skeptical about the problem being the CAI your thoughts are appreciated thanks for your help...
That Mustang Was Fast! It Was Really Hauling Ass When I Passed It!
05-01-2016, 05:58 PM | #2 |
Stovebolt BluFlame 6
Drives: '12 2LT/RS, IBM; '20 Traverse Prem Join Date: Oct 2011
Don't know what causes it, but my 2012 V6 does it also. I notice it at about the same rpm range--20-30 mph in about 3rd gear. It's been doing it since early in her life; has 33K on her now. I believe it has some relationship to throttle plate position and airflow past it. Used to her the same/similar sound with carburetor engines. Sometimes on those it was air leakage around the throttle shaft.
It would be interesting to hear if those who have installed a modified or aftermarket throttle body are experiencing the same whistling sound. |
05-01-2016, 06:03 PM | #3 | |
05-02-2016, 05:38 AM | #4 |
Some here have experienced a "whistling" at certain speeds and have determined it was a result of the wind and the sideview mirrors. Not sure how you could confirm this other than maybe wrap and duct tape a towel around the mirrors and then taking a test drive.
**Find a lightly-traveled road to do this**
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
05-02-2016, 05:46 AM | #5 |
BCS Auto
2015 V6 here. CAI Inc Intake, VMAX Ported Throttle Body, and JacFab Intake Spacer, no whistling here. Had a K&N before the CAI Inc, no whistling there either.
I've heard of the mirror thing as well, FWIW.
05-02-2016, 05:21 PM | #6 | |
here is a video i found on youtube of another car doing the exact same thing at the exact same rpms and the sound is dead on!!! maybe it is the CAI after all i dont know what do you think
05-02-2016, 10:51 PM | #7 |
Guest
It's your intake. Had Cai on my v6 and have it now on v8...plus my 2 for 4x4s. All whistle
05-02-2016, 11:57 PM | #8 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
+2 on the intake as the cause.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
05-03-2016, 05:31 AM | #9 |
Drives: 2010 Camaro SS Join Date: Jan 2015
+3 on the intake being your culprit of whistling noise
2010 Camaro SS Inferno Orange 6-Speed . Edelbrock E Force Supercharger, Volant Cold Air Intake, Magnaflow Exhaust, River City Creations Emblems, Oracle ghosted LED markers, SLP faded gills, ...531 rwhp, 490 rwtq
05-03-2016, 06:40 AM | #10 |
Drives: 2014 2SS/RS Join Date: Dec 2014
To aid in airflow and noise reduction the Chevy engineers carefully designed resonators in to the OEM airtube. Maybe not the perfect intake tube but lots of thought went in to that design. Whistling reduction may have been one goal; but primarily done for airflow.
Below is a good description of the function of the air tube resonators from ehow; and picture of the V6 (V8 similar) OEM tube/resonators. "The Common Misconception -- Most hot-rodders and car enthusiasts think of intake resonators as simple mufflers in the intake tube, devices designed to siphon all the awesomeness out of a car's sound track to appease soccer moms and senior citizens. That makes it a prime candidate for the "chuck-it" school of auto modification. After all, it's basically just a plastic tumor growing off of a tube that should by definition be as smooth and blemish free as possible. While sound control is indeed part of the resonator's job, the sound control itself is really more of a side effect of its primary purpose. Pressure Wave Harmonics Air flowing into your cylinder head's intake port doesn't move in a straight line while the valve is open, then politely stop in its tracks to await another valve opening. When the valve closes, the moving column of air slams into it, then compresses and bounces back like a spring. This pressure wave travels backward at the speed of sound until the intake runner opens up or it hits something, and then it bounces back toward the cylinder. This is the "first harmonic." The pressure wave actually bounces back and forth two or three more times before the intake valve opens again. Intake Tube Pulses The resonator in your intake is technically known as a Helmholz resonator, an acoustic device used to control pressure wave harmonics. Air bouncing back out of your engine and into the intake tube doesn't do it in a single pulse the way it would in a single intake runner; the multiple pistons put out pressure waves at their own intervals, and some of those are going to try to bounce back in while others are going out. The result is a "clog" or high pressure area in your intake tube that ultimately limits airflow through almost the entire rpm spectrum. The Resonator Adding an expansion chamber to the intake tube forces air coming back out of the engine to slow down to fill the cavity, thus expending a great deal of its energy and slowing the pressure wave reversion. This slowdown allows fresh air to flow toward the engine without fighting pressure reversion waves the entire way, thus aiding in cylinder filling. Since these pressure waves are essentially sound, giving them a place to expend their energy before exiting the air filter box ends up dampening the intake noise and quieting the engine. Thus, the resonator helps to make the engine paradoxically quieter and more powerful." Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
05-03-2016, 07:26 AM | #11 | |
Doing what I like to do
Drives: 1963 Landrover Join Date: Nov 2013
05-03-2016, 07:58 AM | #12 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
Question, so the after market intake systems do not have this additional chamber attached, how does that affect these intake systems? Pros/Cons?
05-03-2016, 04:14 PM | #13 |
Thanks for all the knowledge and advice, its really appreciated!
05-03-2016, 04:17 PM | #14 |
Another question (for OP)... what brand of cai are we talking about? I've had a CAI, Inc. intake on my 1SS for nearly 3-1/2 years with ZERO whistling from it. I stiil would check the mirrors first.
