01-25-2012, 08:28 AM | #1 |
Drives: 2010 CAMARO SS Join Date: Apr 2010
A better looking coolant reservoir for your blower
I am getting a chrome maggie and didnt like the black plastic reservoir that is included in the kit...so i found this one from canton racing products it is slightly larger and a good looking tank. i purchased this from TORQ who is a distributor ,,also got the billet cover from them as well...i will be chroming it
01-25-2012, 08:29 AM | #2 |
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS Join Date: Dec 2009
nice. I suppose it doesn't use the same bracket as the Maggie res does it?
01-25-2012, 08:33 AM | #3 |
01-25-2012, 08:40 AM | #4 | |
Canton Makes nice stuff we use it as well. Ted.
www.jannettyracing.com
01-25-2012, 08:51 AM | #5 |
thanks ted....only place it fits is behind roto-fab airbox...do you think that will work...i have it fabbed for the cap to be about 1-1/2 inches from the hood
01-25-2012, 09:23 AM | #6 | |
Then feed directly in to the pump as short as Possible.
01-25-2012, 09:30 AM | #7 |
hmmm...i have seen several installs of stock reservoir on drivers side. so do you think it will cause a problem?
01-25-2012, 09:38 AM | #8 |
I know and we put them back on the pass side, they do it to clear the engine covers.
01-25-2012, 09:42 AM | #9 |
01-25-2012, 10:17 AM | #10 |
Cut the Covers.
01-25-2012, 10:18 AM | #11 |
Most hated in NM....
Drives: Sold the 6POINT2, went to a 50THZ06 Join Date: Sep 2011
I would think that behind the rotofab intake would be too low..... If you look at that spot the hose would have to travel up to get to the maggie itself. Most people that put it on the drivers side mount it up by the brake booster which is higher.
01-25-2012, 11:25 AM | #12 |
so how does roto-fabs coolant reservoir work then....its mounts right where i'm putting mine?
01-25-2012, 11:36 AM | #13 |
I believe that's the wiper fluid reservoir that rotofab made a mount for...not the coolant. Don't want to pee on your wheaties but I'd listen to what Ted is trying to tell you.
01-25-2012, 11:49 AM | #14 | |
Steve, If you look at our WW reservoir tanks you will have a very good idea of what this looks like when installed. The tank body and mounting location are identical-only the top and bottom are changed. Our S/C tank accepts the Magnuson lid and has the 3/4" hose nipples to accept the intercooler hoses. Mike |
Similar Threads | ||||
GTO Clutch Reservoir Install | terry_b | Camaro DIY & HOW-TO instructions & discussions | 68 | 06-13-2014 07:46 PM |
Clutch fluid contamination problems on Vette fixed for Camaro??? | LDGn63 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 11 | 05-28-2012 09:17 PM |
Magnacharger Coolant Reservoir Relocation - Hose Routing? | Kilo-9 | Forced Induction - V8 | 9 | 03-21-2011 04:05 PM |
ECS Big Blower Cam - Results are in with a solid 51 RWHP gain | robertway | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 13 | 02-21-2011 09:38 PM |
maggie coolant reservoir mounting ?'s | Jeddler | Forced Induction - V8 | 18 | 01-29-2011 11:51 AM |
