Old 04-12-2016, 10:44 PM   #1
Redevil1111
Redevil1111's Avatar
Drives: 2014 Camaro SS Convertible
Residue from De-Badging
I recently removed all my emblems from my Camaro and now I have a slight problem.
After I removed all emblems and used go gone to remove as much adhesive as I could, I'm now seeing outlines of the emblems on the paint where they use to be.
I feel like it is just adhesive that I can't get off with what I'm using. So my question to you guys is, what do you think would be best to get rid of this?
If I can manage to get a picture where it shows up, ill post it, but ill have to do that in the morning.
Redevil1111 is offline   Reply With Quote
Old 04-12-2016, 10:54 PM   #2
HAMBO
HAMBO's Avatar
Drives: Supercharged 2013 AGM 2SS/RS
How old is the car (if not your 2014) and was it stored in the sun for past few years? If so could it be some kind of fade around where the badges used to be?
Have you tried hand applying a paint cleaner like Meguairs Scratch X or a light polish?
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports.
1967 Bolero Red 396 SS/RS Convertible
HAMBO is offline   Reply With Quote
Old 04-12-2016, 11:01 PM   #3
Redevil1111
The car is 2 years old, my 2014, I just got it a few weeks ago from a dealership that had it sitting for 2 years...good bet it was in the sun for awhile.
I didn't think to try Scratch X, so I'll try that and let you know how it turns out.
Old 04-13-2016, 12:22 AM   #4
Kleen
Kleen's Avatar
Drives: 2012 SS/RS
A clay bar followed by a cleaner polish should take care of any remaining residue.
Kleen is offline   Reply With Quote
Old 04-13-2016, 12:38 AM   #5
Redevil1111
Thanks for the advice guys, I really appreciate it!
I used the scratch x and it seemed to take care of the remaining residue.
One day soon though I need to wash/wax and polish my car to get it looking great! =)
Old 04-13-2016, 02:03 AM   #6
HAMBO
HAMBO's Avatar
Great! Glad it worked out. Let's see some pics soon!
2013 AGM 2SS/RS
Old 04-13-2016, 06:30 AM   #7
Gayton81
Gayton81's Avatar
Drives: 2012 2SSRS
3m adhesive remover does good too without damaging the paint
Money may not buy happiness, but I'd rather cry in a Chevy than in a Ford!
Gayton81 is offline   Reply With Quote
Old 04-13-2016, 03:25 PM   #8
Redevil1111
Got it all cleaned up and some pics...check it out.
My plan is to put the old Camaro V-Flag in place of where Camaro was spelled out
Old 04-13-2016, 04:36 PM   #9
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
I would use Goo Gone or maybe even rubbing alcohol to remove the residue, then I would polish the area then apply wax or sealant.
Old 04-13-2016, 04:54 PM   #10
scandata
scandata's Avatar
Drives: 2015 2SS/RS vert, Spring Green Edtn
I've only de-badged once, to remove the dealer's logo from the trunk. I was surprised at how quick and easy it was to do. Took about 10 minutes, and half of that was getting the tools together and putting them away afterward.
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015)
http://img.photobucket.com/albums/v692/scandata/sigpic_zpsxmxmbipg.jpg
scandata is offline   Reply With Quote
Old 04-13-2016, 04:59 PM   #11
HAMBO
HAMBO's Avatar
Seems OP had originally tried goo gone and it didn't finish the job. I had a similar issue as well when I removed my stock badges.
Great advice on the wax/sealant!
2013 AGM 2SS/RS
Old 04-13-2016, 05:10 PM   #12
nickiscoolerthancool
nickiscoolerthancool's Avatar
Drives: '14 Camaro SS - Airlift
I debadged my car after a year and I found that rubbing off the glue from the badges with my thumb came off pretty easy... Other than that, if the sun hit the car in the right spot you could still see the outlines of the badges. A full detail should do the trick!
nickiscoolerthancool is offline   Reply With Quote
Old 04-13-2016, 08:41 PM   #13
JerTM
JerTM's Avatar
Drives: 2011 2SS/RS M6
I used scratch polish and a microfiber cloth with gentle pressure. Changed the junk right off.
JerTM is offline   Reply With Quote
Old 04-19-2016, 09:33 PM   #14
69L48Z27
69L48Z27's Avatar
Drives: 2015 Z/28; 1969 Camaro SS
Xenit from Stoner works much better than Goo Gone. Never was impressed with Goo Gone.
69L48Z27 is offline   Reply With Quote
