JDP Motorsports
Old 11-28-2013, 09:19 PM   #1
hworth18
Jus' Cruzin
hworth18's Avatar
Drives: 2017 Camaro 1SS Krypton Green
Installing Catch can/removing shrink fit connections?
I am installing the Elite catch can on my LLT and I need to know how to remove the shrink fit connections on the line from the rear valve cover to the intake manifold. Do I cut them off?
I did a search but couldn't find anything and the online instructions from Elite are just about worthless, so any help would be appreciated!!
Thanks!
Harry
“The moment you think you know what’s going on in a women’s head, is the moment your goose is well and truly cooked”
-Howard Stark
hworth18 is offline   Reply With Quote
Old 11-28-2013, 09:25 PM   #2
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
You need to cut the tube about an 1-1.5" from the connector on the IM and 2-2.5" from the valve cover side, essentially removing most of the plastic tube and just leaving a bit on each end. Then connect the hoses in between.
Here is a pic with the RX can but its the same install:
Sent from my 2SS/RS
FSP tuned: 377/389
Old 11-28-2013, 09:29 PM   #3
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Heat up the tube near the connector and pull it with a pair of pliers. Removed all mine that way, when the tube is off the connector it has O-rings on them.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 11-28-2013, 09:51 PM   #4
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
That's how I did mine, got rid of the tubes completely and just connected the hoses right onto the fittings
terry_b is offline   Reply With Quote
Old 11-28-2013, 11:21 PM   #5
hworth18
Jus' Cruzin
hworth18's Avatar
Thanks guys!!!!
-Howard Stark
Old 12-04-2013, 08:13 AM   #6
hworth18
Jus' Cruzin
hworth18's Avatar
I ended up taking a sharp exacto blade and slicing the shrink fit tubing off the elbow connectors, it worked great! Thanks for the input guys!!
-Howard Stark
Old 12-04-2013, 09:18 AM   #7
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Those hoses are a pain.
