BORLA
Old 11-29-2013, 06:31 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Exclamation ac off due to engine over temp
has anyone found a fix for this problem only comes on when engine is cold under first start I have replaced the temp sensor and the pigtail and the light still comes on every now and then when I first started up
MODS 6.0 forged iron block, Texas Speed Stage3 cam, custom twin turbo, Tripple 450 pumps, DW2200cc injectors, BMR Springs, sways, endlinks, bushings, tailing arm, toe links, DSS aluminum driveshaft, G-Force 1000hp axles, Brake master drilled rotors, ACT twin disk (1550ftlb), MGW shifter, Race Star wheels 17x4.5 with MT front runners 15x10 with Hoosiers, AEM gauges, G-Force II boost controller
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 11-30-2013, 07:09 AM   #2
2010_camaro
Guess not?
Old 11-30-2013, 08:14 AM   #3
RubyCamaro
Jan
RubyCamaro's Avatar
I only have a vague recollection on this having been mentioned before. Try doing a search. Use advanced search & limit it to thread titles. Keep bumping the thread too. Not many folks online during the holidays. Hope you find some answers.
Old 11-30-2013, 09:21 AM   #4
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Is the gauge under the tach going into the red? CEL?
Old 12-01-2013, 06:41 PM   #5
TooCool5
TooCool5's Avatar
If it is cold out and the AC is off it is probably an electrical fault at boot up.
You could try re-seating the main harness to the ECU as well as any related circuit wiring, also check for service bulletins.
Old 12-02-2013, 06:25 AM   #6
2010_camaro
Lol no.
It use to only happen a few times during winter. Only does it when its rather cold out and within 30 seconds of the first start up. Now it has become worse. The problem seems to happen about every third or fourth time i start it in the mornings. So ill let the car run for a few minutes shut it off unhook the battery start it back up and she's fine. Also when this happens my temp gauge stops working. I've had it at the dealer but they don't know what's wrong. The dealer knows of all my mods and doesn't care. They fib a little to keep my car in warranty!
Old 12-02-2013, 02:05 PM   #7
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
Does the AC have it's own fan? Most imports have a designated fan. When the AC is on the fan runs while the AC is powered up.
Old 12-02-2013, 09:57 PM   #8
2010_camaro
its got two fans. They both kick on when the issue happens.
Old 12-03-2013, 08:31 AM   #9
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
How long have you had the Trifecta tune? Before this all started?
Old 12-03-2013, 12:49 PM   #10
2010_camaro
this started before I was modding back when I bought the car new.
Old 12-06-2013, 06:59 AM   #11
2010_camaro
anything?
