01-13-2016, 04:47 AM | #1 |
Drives: '13 1SS Camaro Summit White Join Date: Jun 2013
Rotational noise?
Hello,
So I just lowered my car the other day and changed the transmission and diff fluid on my camaro (5th gen ss '13). After driving it normally I didn't hear any weird noises. However, after letting the car rest for a couple of hours, I hear a sound that seems to be rotational and coming from the back driver side. The way I can describe the sound is as if some part of my car is rubbing against something (metal?). This sound only happens when I am leaving my drive way on first gear and at very low speed (3mph-5mph). And I can count how many times I hear the rubbing sound which is about 4-5 times. After leaving the drive way and hitting normal driving speeds, the sound is gone. Any thoughts about this. Thanks! |
01-13-2016, 06:02 AM | #2 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
I would look at the backing plate and see if you might have bent it in a little where it scrapes against the rotor at times. If it looks close just pull it back a little and see if it takes care of the noise. That would be about the easiest thing it could be anyway.
3.6L Twin Turbo V6 Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension 10.75 @ 131mph |
