01-03-2017, 10:37 AM | #1 |
Drives: 2010 Camaro SS Join Date: Jan 2015
Return fuel system question
I just upgraded the fuel system in my car, my question is what are you guy's setting your base fuel pressure to (vac line off reg)?
Here the new fuel system Fore dual 450's 1000cc injectors -8 feed |
01-03-2017, 11:11 AM | #2 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
Normally the stock 58 with vac line off, but some do go a little higher depending on injectors, fuel type, pressure drop, flow, etc...
01-03-2017, 11:14 AM | #3 |
I'm currently set to 58psi vac line off, I just was not sure if that was correct.
01-03-2017, 11:32 AM | #4 |
Drives: 2014 Camaro 2SS 1LE Join Date: Jul 2015
My tuner set my 850 to 58psi no vac- and sad it's what it's should be, but with 1400cc we lowered to 43 to make DD on pump gas
AGP TT 807whp 811wtq 13.46psi E85+methanol
01-03-2017, 12:51 PM | #5 |
Drives: Anything I want Join Date: Oct 2008
42 is what we run
Do go below 38 or the jet pump may stop working.
We run 42 on our cars. |
01-03-2017, 01:30 PM | #6 |
01-03-2017, 04:32 PM | #7 |
anybody else have input on this?
01-03-2017, 04:40 PM | #8 |
Depends on injectors, max boost, etc etc etc.
If you can support the flow at lower pressure, go for that. If you need to run higher pressure do that. Be aware that some injectors don't like super high pressure, so make sure they are compatible with the max psi if you are going to run a lot of boost. Also depends if you are running a 1:1 regulator or what. Talk to the person who designed your fuel system.
Nick
Corvette Z06 -1200ish rwhp |
01-03-2017, 05:01 PM | #9 |
Drives: 2012 2ss/rs L99 Join Date: Jun 2015
I have dual walbro 450s with same feed size and e85. I'm running 43psi vac line on with id1000s
2012 2ss/rs L99
Agp twin turbo 51/61 full 3 inch stainless works retro chambered catback Tuning by Greg Adams |
01-03-2017, 05:18 PM | #10 |
What if any advantage is there to running lower base fuel pressure?
01-03-2017, 06:50 PM | #11 | |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
I wondered if it would be beneficial too but my tuner wanted it set to base of 58psi and it was fine, plenty of fuel easily for 800+whp on full e85 with dual walbro 450 pumps and 1000cc injectors. Know of another same setup just did 830whp That being said run it by who is going to tune the car and see what they prefer
01-03-2017, 08:30 PM | #12 |
Drives: Red Jewel Camaro SS Join Date: Mar 2014
I set mine at 58psi with no vacuum.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
01-03-2017, 08:33 PM | #13 |
Sounds like 58psi is it unless my tuners says otherwise
01-03-2017, 11:45 PM | #14 |
Yes 58 with no vac
2012 2ss/rs L99
