07-27-2012, 08:21 PM | #1 |
COTW 11/12/12
Drives: 1SS RS IBM Join Date: May 2010
Dose this Dyno Graph look right to you (turbonetics turbo LS3)
Just had the car dynoed and tuned in Chicago IL. The graph looks nothing like im used to and when I asked the tuner he said it was normal. Ive talked and showed the graph to a few people sense and they dont agree. What do you guys think.
Thanks for the help Ben
07-27-2012, 08:25 PM | #2 |
Drives: 08' F250 Diesel & 10' Camaro 2SS Join Date: Nov 2010
Should be alot smoother and not have the large dip either.
08' F250 CCSB 6.4L Diesel White & Black, Blacked out, 580RWHP @ 55psi 13.21 @ 101mph
10' Camaro 2SS LS3 M6 White & Black, Blacked out, 684 RWHP & 633 FT.LBS @ 10psi 10.82@130mph TVS2300 ,Hendrix Street Slayer Twin Carbon Clutch, Dana 60 3.73, DSS 1400HP Axles,JRe cam & LaMotta Performance tuned,LPE Fuel, AI Super Chiller,MT ET Streets |
07-27-2012, 09:18 PM | #3 |
Drives: Silverado Join Date: Feb 2012
07-27-2012, 09:54 PM | #4 |
Mad Ninja Skills
Not that unusual. I agree the tune could definitely use some work. would like to see what knock retard was right around 5k rpm. smoothing was set to max at 5 (upper right corner of sheet) which would usually give you a little smoother graph, but is the reason for the blank spots towards the end of the run. You got a big spike in the torque towards the end of the run (probably lost tach signal for a sec) , and that spike went through the hp line. with the smoothing set to 5 it gets rid of the spike on the graph, but you still loose that section and where it intersected the hp line.
2011 Camaro SS/RS M6 - 633whp/679tq Gave to the wife
Custom stainless 2" primary headers / Custom stainless 3" header back exhaust / Hurst short shifter / ZEX nitrous kit / Vararam intake / Spohn chrome moly trailing arms / Sin City Performance Tune / SCP custom ground cam / SCP ported & polished heads New Car 2007 Corvette Z06 - Headers / Vararam / Magnaflow Catback / SCP Tune / Nitrous / BTR Stg IV Cam and Springs |
07-27-2012, 10:15 PM | #5 |
Drives: CGM,twin turbo, cam 2010 SS/RS Join Date: Mar 2011
a/f looks good, smoothing is on 5,.... could be alot of things and the graph doesnt really say much cant really say its awful tune by looking at a wavy graph but we can all guess and throw a million ideas at you. If you worried about it take it somewhere and get a second look or go back to speed inc and tell them to explain why and/or fix it. Are you still on the Stock Clutch????
07-27-2012, 10:26 PM | #6 |
COTW 11/12/12
Thanks for the help i am on the stock clutch i havent noticed any slippage or smell. Speed inc said it was normal i am having a second place do a base line to confirm all is well
Ben
07-27-2012, 10:39 PM | #7 |
Yeah I think would be best could be a few different things. not the first wavy dyno sheet I've seen posted from that dyno. Could be something very simple they missed but I wouldnt call it Normal.
07-27-2012, 11:35 PM | #8 |
COTW 11/12/12
Let me ask u guys this if there is an issue or a short cut was taken during my tuning session do i have a leg to stand on to call speed inc and try and get some compensation having to pay to have the car tuned twice with in a week
Thanks Ben
07-28-2012, 12:00 AM | #9 |
I think you always do better to go back and talk to speed inc. Tell them whats going on and see what they say. Tell them what you want. They have been around a while not known to be hacks from what I know. Remember your the customer. If they dont want to help you then take it somewhere else and see what they say then come back and tell us all about it!
07-28-2012, 12:06 AM | #10 |
If its how their dyno looks then take it as is to another dyno and compare it. If its smooth looking on another dyno then its fine if not ask them why.
07-28-2012, 12:11 AM | #11 |
Yeah The Wavy lines would be alot worse If it was a pick up issue with the dyno unless they have something rigged. But thats a good Idea that turbo said then you can atleast compare numbers too.
07-28-2012, 02:59 AM | #12 |
Drives: 2010 SS, 06 SRT10 Ram Join Date: Nov 2011
wtf...thats one of the ugliest dyno graphs i have ever seen....
07-28-2012, 08:34 AM | #13 |
Drives: CTS-V Join Date: Aug 2008
@ 5000 rpm car is
not happy
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
07-28-2012, 10:19 AM | #14 |
Drives: Blown G8 GT Join Date: Apr 2010
Looks like my old dyno graph when I had no fuel up top and injectors maxed out. Dropped right off as rpms climbed.
Have your fuel tables, timing and Maf curve looked at. Make sure it's adjusted and gradually ramped up as boost builds. Makes for a smoother transition into power and watch air fuel gradually go where you want. |
Thread Tools | |
