07-16-2015, 01:30 PM | #1 |
Go fast, please.
160 degree thermostat..?
I have seen a few threads on this and it is unclear as to whether or not I personally should do this...
I am going to have a 28%OD pulley put on here shortly, would this benefit me and the higher temps this will cause, or am I better off leaving the thermostat stock? |
07-16-2015, 01:36 PM | #2 |
Drives: '21 ZLE A10 Join Date: May 2012
do it...easy swap and there are no negatives with it. My Z/28 has a factory 160 thermostat so I suppose GM is taking a different stance on the seemingly winless argument.
07-16-2015, 01:37 PM | #3 |
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray Join Date: Feb 2013
2015 Z/28 #642 Black Bad Ass
07-16-2015, 03:25 PM | #4 | |
Go fast, please.
Looks like I am going to add this to the list of mods then. Thanks! |
07-16-2015, 11:06 PM | #5 |
JMOP...when Chevy was looking at the gas guzzler tax, the 160 degree thermostat did not make a diff on the LS7.
07-17-2015, 07:09 AM | #6 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
So does the GM 160 deg thermostat fit other LS engines. I think there are only two designs, the early LS1s and everything else later.
Bryan 2018 ZL1 M6
07-17-2015, 07:30 AM | #7 | |
Ed
Drives: 2013 AGM Camaro 2SS/RS/1LE Join Date: Dec 2012
07-17-2015, 11:23 AM | #8 |
Go fast, please.
07-17-2015, 11:28 AM | #9 |
Go fast, please.
There is so much back and forth in these threads about the 160 degree tstat... It really makes it hard to make a decision based on FACTS.
07-17-2015, 01:26 PM | #10 |
early style LS1 the water neck and thermostat was one piece...now the thermostat is separate from the water neck. So, yes...only two designs.
07-17-2015, 01:32 PM | #11 |
07-17-2015, 06:50 PM | #12 |
Drives: 2012 ZL1, 1996 Z28 Join Date: Jun 2012
Anyone have the gm part number for the z28 tstat?
07-17-2015, 07:37 PM | #13 | |
Ed
2. If it's a race motor and gets the oil changed after every race or two, then oil sludge, because the motor never gets hot enough to burn it off, isn't a problem Street cars/motor are likely to face both #1 and #2, so use at your own risk. Last edited by BigBlock69RS; 07-17-2015 at 08:02 PM. |
07-17-2015, 09:45 PM | #14 | |
Drives: 2015 ZL1 Join Date: May 2015
The one in the pic seems to have 4 holes in it also. |
Thread Tools | |
