04-26-2017, 12:59 PM | #1 |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
New Race Star Recluse drag setup
Finally getting into a proper drag setup. I would have loved to get a set of Welds but I'm too poor and impatient. So I decided on these new Recluse wheels from Race Star. They are direct drilled and use regular conical lugs, so no messing with the old style shank lugs. I went with 17x4.5 front, and 17x10.5 rear. They seem to clear everything including the SS brembos. The fronts have a ton of clearance(supposed to clear ZL1 calipers) but the rears are very tight. Looks like 0.10" or 2.5mm between the caliper and the barrel of the wheel. I think that should be enough though. The fronts weigh 19lbs and the rears weigh 24lbs, not the lightest but not bad. They seem to be about 2lbs heavier than the original race stars size for size.
I ordered them from Pro stock John who was great, had no problem answering all my questions and gave me a really good price. Shipping was very fast. I would definitely order from him again. Now i need some tires... I think I'm going to go with the M&H 325/45R17 drag radial for the rear, and a 28" radial skinnys for the front.
3.6L Twin Turbo V6 Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension 10.75 @ 131mph |
04-26-2017, 01:02 PM | #2 |
The tires aren't mine, found the pic off the forum. But these are the sizes I'm thinking of going with.
04-26-2017, 04:07 PM | #3 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
almost to purrty to put on and get dirty!!!! lol...I need some rear DR's..was that model avail in black?
should be a sweet setup...
04-26-2017, 05:21 PM | #4 |
Drives: 2010 Camaro SS Victory Red Join Date: Apr 2015
Going to be nice setup, gotta like a camaro with skinnys
Speed Engineering Headers w/ Texas Speed HFC's ~ Flowmaster 2 1/2" cat back w/Flowmaster Super 10's ~ Cold Air Inductions Intake w/ Scoop and WW relocate ~ VMAX CNC Spiral PTB ~ Cross Drilled and Slotted Rotors w/Hawk pads ~ ZL1 Spoiler ~ SCTX4 RDP Tuned
04-26-2017, 07:24 PM | #5 |
They are, but the 17x10.5 in black was out of stock until mid June. That's why I went with chrome. It's not really chrome though it's a powder coat process that looks exactly like chrome. Both weigh the same.
04-26-2017, 07:40 PM | #6 |
Look like a nice piece! I need some fronts myself.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
04-26-2017, 08:03 PM | #7 |
I need a drag pack setup! Skinnies up front and a 15" conversion in the rear!
Instagram @orange_maro_
04-26-2017, 08:18 PM | #8 |
Drives: 2014 1SS/RS LS3 Join Date: Jul 2012
Ive got the same rears but black and I went with the 7" wide fronts. Here are some pics of the 325/45 m&h mounted up.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
04-26-2017, 08:59 PM | #9 |
Very nice looking set of wheels!
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, RPM 5” CAI, Kooks Headers, Solo Cat Back, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
04-27-2017, 07:12 AM | #10 |
"Old School"
Drives: 2010 2SS L99 Join Date: Apr 2015
Those are really nice. What is the powder coat process that looks like chrome? Who does it?
04-27-2017, 09:36 AM | #11 |
Instagram: Sangstah
those look mean, cant wait to see em mounted!!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
04-27-2017, 01:36 PM | #12 |
I have the 10.5" rears in black with ET Street Rs 305/45/18. I decided to go with the 8.5s with Pirelli P Zero Rossos 255/55/ZR18 in the front. I am still waiting on the front to ship due to back order. Love the looks and i believe they are black chrome not powdercoat. The rears weighed 5.5# each lighter than the stock wheels and tires.
1967 Camaro Resto Mod. 468 roller. Tremec TKO600, 2011 Imperial Blue Metallic paint, full Hotchkis suspension, Wilwood disc brakes, Ron Davis radiator, Comp Cam, Custom aluminum air intake, custom valve covers, Rushforth rims, ET street radial IIs
04-27-2017, 02:21 PM | #13 | |
"PVD (Physical Vapor Deposition) coating is an alternative to the standard chrome plating method used to coat aluminum vehicle rims. PVD is a layering method, which sandwiches a metal alloy in between a base and top coat of powder coating." It's pretty cool, but it's not near as durable as chrome. It scratches like a clear coat. My '17 F-150 has the same finish on its wheels. I have to be careful wiping them with towels or it'll put little scratches in them. Here what it says on the wheels:
04-28-2017, 11:25 PM | #14 |
Drives: Z06 wannabe Join Date: Feb 2015
Those look nice.
Apex Focused
