05-20-2010, 02:33 AM | #1 |
Drives: blacked out 2010 Camaro Join Date: May 2009
kooks n stock cats??????
Can i run stock cats on kooks LT headers? or do I need to get high flow cats?
thanks |
05-20-2010, 02:39 AM | #2 |
if im not mistaken.. long tube headers mean the place where stock cats are is now non existent..
if you want cats.. you will have to weld stock ones on .. or get a high flo catted x pipe.. I would go with catted x pipe for additional gain |
05-20-2010, 02:50 AM | #3 |
I have the magnaflow tru x pipe installed, will that work??
05-20-2010, 03:00 AM | #4 |
if there are no cats on the x pipe.. you will need to have cats installed between the c pipe and headers somehow.. unless they are catted headers
or you can go without cats.. |
05-20-2010, 03:05 AM | #5 |
Drives: C63 P31 Join Date: Feb 2010
I was told that I could run stock cats with ARH LTs so wouldn't it be the same with Kooks LTs? Admittedly, I don't know how LTs connect to cats. Can u use brackets or do u need to cut and weld?
05-20-2010, 03:05 AM | #6 |
I was thinking of going without cats....n maybe add highflow cats when emission time comes around
05-20-2010, 03:07 AM | #7 |
I don't see why they would differ ill have to ask when I call an order them tomorrow
05-20-2010, 03:08 AM | #8 |
Don't the LT collectors come right before the cats, whether they are stock cats or high flow cats?
05-20-2010, 03:12 AM | #9 |
05-20-2010, 03:12 AM | #10 |
05-20-2010, 03:19 AM | #11 |
05-20-2010, 05:55 AM | #12 |
Okay guys.. i did the HW for you and i hope it clears things up
as you can see from below and as i said earlier, the location for cats is now non existant. Below you can see headers with a high flo catted x pipe So now as you already have an x pipe, and I am imagining you are not going to buy a new one, you can either go cat-less or cut and weld high flow/stock cats to your x pipe. if you cut and weld, i doubt you can remove them again without the need to weld the piping you removed back on and you would just weaken the pipe. So IMO buy catted headers with high flow cats like the ARH below and use them with your cat back. Dont forget the tune to avoid any lights coming on on your dash too. |
05-20-2010, 06:49 AM | #13 |
BAMF SS
sigh....
A) factory cats do not bolt up to kooks long tube headers. or ANY longtube header at that. B) if you want to use your factory cats with your longtubes (i have no clue why you would want to do such a thing though), you will have to put buy a reducer to go from the kooks 3" collector to the 2.5" cat inlet. C)take off your stock cats... take them to a scrap yard. There are precious metals in it and they will pay you for them. The 2010 camaro has 2 cats and 2 pre cats. I got $100 out of mine. Use that money to buy a set of catted mid pipes from kooks, which will work with your magnaflow xpipe, whether your x-pipe be 2.5" or 3", because kooks offers a mid pipe to connect ot the stock exhaust (2.5") or their catback (3") If you run catted mid pipes and plug in your rear o2 sensors properly, YOU WILL NOT have a check engine light come on.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. Last edited by danhr; 05-20-2010 at 07:00 AM. |
05-20-2010, 07:46 AM | #14 |
Thanks for clearing things up guys. You both obviously know what you're talking about.
Similar Threads | ||||
lt headers& stock cats | spryc5 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 04-22-2010 06:31 AM |
L/T headers, hi-flow cats and stock resonator. will I have exhuast drone? | bumblebeecamaro | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 4 | 04-20-2010 06:05 AM |
