06-08-2010, 09:03 PM | #1 |
Corvette and Camaro lover
Drives: 2010 Camaro...some day... Join Date: Apr 2008
Is This Combo Possible?
Simple question, can you mate a a modern day engine, like a second generation LT1 small block V8, with an older transmission, like a Muncie M20? Why or why not?
06-08-2010, 09:11 PM | #2 |
Drives: Love the one you're with Join Date: Sep 2009
06-08-2010, 09:13 PM | #3 | ||
Truth Enforcer
Drives: anything I can get my hands on Join Date: Sep 2006
just get the right adapters.
A group as a whole tends to be smarter than the smartest person in that group until one jackass convinces everyone otherwise. Quote:
06-08-2010, 10:08 PM | #4 |
Back on the dino-juice
Drives: '10 LS + a few more Join Date: May 2010
The LT1 has the same bell housing pattern as the original 327/ 350/ 396/427 do you see where I'm going? It needs no adapters. It would need the LT1 flywheel I do believe. The LS series small blocks need a special bellhousing and motor mounts.
06-09-2010, 04:28 PM | #5 |
Drives: 1976 Camaro Join Date: Jul 2009
I had a 79 camaro 350 with a muncie m20
06-10-2010, 12:48 PM | #6 |
Was it an LT1? (the engine)
06-12-2010, 07:56 PM | #7 |
There were two distinctly different versions of the LT1. The first LT1's came out in 1970 and were a stout 350 that had a solid-lifter cam and had a distributor put behind the carb. The next LT1 came out in 1993 and again it was a 350 and was a fuel-injected version of the small block with a reverse flowing coolant system and the distributor was an opti-spark setup that sat behind the waterpump and had issues until the vented versions came out. Both were stout and put out nice power/torque. Blocks were externally the same, so I'm saying you don't need special adapters.
06-12-2010, 09:51 PM | #8 | |||
Truth Enforcer
as far as the different LT1s... yes and no. if you want to get nit-picky the engine that came out in the 70s was an "LT-1" while the one that came out in '92 was an "LT1" (without the hyphen)
Similar Threads | ||||
LG g6x3 and 4:10 gear Combo...My Feedback | Mr. Brownstone | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 40 | 02-24-2010 12:41 PM |
GTS Exterior Styling Combo Pack - save $$$ @ PFYC.com | Redshift | Exterior Parts & Accessories | 0 | 12-03-2009 03:13 PM |
Thoughts on this combo.....SIM(Silver on Silver Rallys) | DCJ | 5th Gen Camaro SS LS LT General Discussions | 10 | 07-11-2009 08:38 AM |
