09-05-2014, 08:51 AM | #1 |
McLeod slave cylinder
Just seeing if anyone else has tried it and your thoughts. Do you like it,did it change the pedal travel and stiffness ? Thanks
Forged LS3 416ci, Maggie TVS2300 @ 13lbs boost, McCleod twin disc clutch, GForce 1320 nine-inch 389 gear ratio, Hurst line-lock, 750 whp 700 wtq |
09-15-2014, 08:03 PM | #2 |
Emerald Coast Camaros
Drives: 2010 2SS 6m Join Date: Mar 2010
Location: Fort Walton Beach...surrounded by da** pickup trucks I can't see around!
Bump for this info too. Would like to know.
Procharged F1A-94 on a 416 LSA block, Callies/Manley/Scat/Melling/Cloyes/ARP/Ferrea/Landspeed/Hi-Ram/FIC/Tick/Alky/ Strange/QA1/DSS/BMR/RPS/Tilton/GZM/Fore/AEM/ATi/JGS etc., built/tuned by me and Innovative Street Technologies
'Mo's Seemingly Endless Build Thread |
09-24-2014, 06:00 PM | #3 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
Just installed one along with a center force DYAD twin disc so far it seems to be better than stock, but it's still early.
09-26-2014, 09:18 AM | #4 |
Drives: 2014 SS Join Date: Jan 2011
Instead of trying to recreate the wheel we addressed the problematic release bearing issue by replacing/upgrading the faulty plastic bearing support with our billet steel support. By doing this you remove the "weak link" in the slave and eliminate the issue all together. The slave and bearing itself isn't the failure point on these cars.
Here is what the factory plastic piece that I'm referencing - Here is our billet upgrade - |
09-27-2014, 07:41 PM | #5 |
Now that looks sweet, wise I would have known about that beforehand.
09-29-2014, 09:55 AM | #6 |
10-01-2014, 10:21 AM | #7 |
No different
So installed the McLeod slave cylinder and it works great. Has the same feel as the stock one and seems to work perfectly. But can anyone tell me why under full throttle long pulls in second or third gear my pedal still pulls away from my foot?
10-01-2014, 10:27 AM | #8 | |
We can help you out with one of our new LT1-S twin discs, it's fantastic to drive on the street. That said, you can research the LT1-S on this forum and see that many others love it. Give me a shout and we'll go from there, even if you don't buy our unit I'll help answer any questions you may have. |
10-01-2014, 11:01 AM | #9 |
Drives: 2010 zr1 Camaro 2011 vert Join Date: Apr 2013
I wish I could have caught you earlier. There is no need for anything than stock gm components with the Street Slayer, it is built specifically for your 5th gen and another reason it's such a great value.
