01-04-2014, 08:56 AM | #1 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
Possible to adjust 2013 power steering assist?
Is there an area in the car's programming (tune) that can adjust the amount of assist that the electric power steering provides?
Does anyone know how the electric power steering works on these cars? Have power steering but no variable assist after tune, at any speed. Usually there would be more assist at low speeds but there isn't any (just the plain power steering as if driving high speeds). I'd think if some speed sensor was not working then I'd get over assist at all speeds, but that's not the case. I'm getting no additional assist at any speed, but still have power steering.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
01-04-2014, 08:59 AM | #2 |
No there isn't, but its quite possible that if the car is reporting more tq it is altering the amount of steering assist.
01-04-2014, 11:04 PM | #3 |
Drives: 2020 ZL1 1LE Join Date: Sep 2012
Putting the car into Competitive Mode will change effort. Holding down the button for a full 12 seconds (which fully kills all the nannies) will change it further in that the higher effort is at low speeds as well. However it has been a while since I checked that....
01-05-2014, 09:22 AM | #4 | |
Drives: 2013 / 2SS / RS / L99 Join Date: Feb 2009
01-18-2014, 02:26 PM | #5 |
Discovered the Tru-Boost controller bezel mounted in a SLP steering column pod was interfering with the back of the steering wheel during turns. Looks like about 1/8" or a bit more of the back of the bezel needs to be removed so that the gauge/bezel clear the back of the steering wheel.
