01-25-2015, 11:41 AM | #1 |
Thread Ender
Drives: 2010 Camaro 2SS/RS L99 Join Date: May 2011
Bald Pirellis to General GMAX AS-03 turning/traction control light problem
Posting this in general because I honestly don't know what the cause is...
Recently I had switched from balding rear Pirellis to General GMAX AS-03s and had some confidence going into December in NJ, since last years debacle called weather, but have noticed some... abnormalities. I have Pirellis on the front still, but the AS-03s are on the rear. If I get on an off-ramp (with a slight decline/curve) at about 40-45 on the turn I get a traction control light and "shudder" caused by what I will assume is the traction control system (Sounds like when you run over the rumble strips on the highway). The speed shouldn't be the issue because I know I have taken this route/speed with the older tires (albeit, better weather). I don't recall if it ever did this when I had all 4 Pirellis. The only constants I can find is... I don't have the same tires on the front and back (having a hard time thinking this has much/anything to do with turning) and the weather has been 20-40 degrees out since I changed the tires. Cold ground screwing up new tires traction? The Pirellis just alot better/"grippier" tire when it was warmer? Who knows, all I know is its weird and I am at a loss. Unexplained happenings, while consistent when they do, annoy me. Any ideas? |
01-25-2015, 03:16 PM | #2 |
Drives: 2013 Camaro ZL1, 2006 Chevy Equinox Join Date: Apr 2013
The gmax tires are an all season tire so they have less grip. I own a set of them and they are crap in my opinion. They are decent for all season, but as summer tires they are not good. I have owned them for 1 summer and will be getting some nice yokamas again this spring. Sounds like you just spun the tires going around the he corner. The gmax are not that performance oriented. Check out the tire threads if you want something more performance based. Honestly my favorites are yokohama (s-drive or better), toyo (R888 are very good) and had good luck with some hankook models, Michelin also makes some good performance ones as well but I found they wore really fast. Everyone has their opinions on them, just don't buy pirellis again, most overpriced tire out there.
01-25-2015, 03:47 PM | #3 |
Drives: 2010 SSII w RS & Sunroof Yellow Join Date: Aug 2009
Location: West Suburbs of Chicago, in a Courthouse Somewhere
Anytime you have two different types of tires front to back you are asking for trouble. They don't grip the same and it makes it harder or you to tell when you have reached that point of no return. Unless of course you are on a drag strip.
01-25-2015, 03:50 PM | #4 | ||
Thread Ender
Thanks, Jason |
01-25-2015, 06:10 PM | #5 |
Drives: 2011 IOM 2SS/RS M6 Convertible Join Date: Feb 2014
If you're driving in temps below freezing, I'd get some all seasons on the front also, the Pzero's have very little grip at those temps. You need appropriate tires on all 4 corners, not just the drive axle.
01-25-2015, 06:24 PM | #6 | |
Thread Ender
Thanks, Jason |
