08-05-2014, 06:35 PM | #1 |
Drives: Black 1SS/RS LS3 M6 "The Toy" Join Date: Dec 2011
Engine transmission
Any one have any tips tricks to get the engine married with the transmission have been trying all day to get it lined up and no luck.
Any help would be greatly appreciated as I'm about to light it on fire and call it a day.
2010 1SS/RS Diablo Sport Trinity JRE Tune OBX headers with Cat delete Borla Cat back Volant PowerCore CAI BMR adjustable trialing arms 4.11 Gears JRE cam package.
08-05-2014, 08:13 PM | #2 |
Drives: bicycle Join Date: Jun 2014
hate to say this but a transmission jack will make your life much easier,, see if you can rent one from an auto parts store or if you can borrow one from you local shop
08-05-2014, 08:52 PM | #3 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
For sure a trans jack will help a ton.
08-06-2014, 02:57 PM | #4 |
Drives: 416 w/TH400 Join Date: Mar 2012
off topic but I guess u got the crank and rods?
ERL 416 - 12.5 cr, TH400, Custom VVT Cam, PRC 255 heads, NW 102 TB, Aeromotive stealth fuel system, Fast 102 plumbed with a nitrous express direct port kit, BMR 15" conversion kit
08-08-2014, 10:40 AM | #5 |
Thanks for the help and yes got the crank and rods thanks for helping out with that Bplum...
08-12-2014, 10:11 AM | #6 |
Well could not get the engine lined up on the trans so I just pulled the trans got it together then put it back in the car. Started up, engine runs well just have some major vibration coming from the trans drive shaft trying to figure out exactly what it is. When I roll down the road the trans starts to shake and shifter starts to shake very bad. Any suggestions?
08-12-2014, 10:19 AM | #7 |
Geek
Yikes. Did you hang the tranny off the input shaft? Sounds like something isn't straight.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
08-12-2014, 10:44 AM | #8 |
pulled the trans mounted to the engine, doesn't feel like it is there more where the trans mounts to the drive shaft it is fine at about 2000 rpm then starts to wobble after that about 25mph and over. Feels like the drive shaft starts to loop.
08-12-2014, 11:47 AM | #9 | |
Ted.
www.jannettyracing.com
08-12-2014, 12:44 PM | #10 |
Just got back from the trans shop said it look like the trans mount was shot so will start there.
