02-26-2017, 11:55 PM | #1 |
Drives: 2016 2ss, Rip 2013 zl1 Join Date: Dec 2013
Is something wrong with my car
Ever since i got the car it has seemed slow to me. I was getting on the highway the other day was doing about 70 shifted down to 4th stepped on the gas to get in front of a truck and the car just did not want to move like a 500hp car should. It has always been like this. My 13 ss ls3 had way more kick than this and my friends 5.0 has way better pickup at these speeds. The car has great performance at speeds below 55 once you get beyond that the car is like a dog at wot no matter what gear. Is this just me of do you think something is wrong. (I have tried a fuse pull already)
2013 zl1 manual only mods so far cai, Ported tb I always use 93 octane. |
02-26-2017, 11:58 PM | #2 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Ditch the cai and see if you still have the same results after doing another fuse pull.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
02-27-2017, 12:08 AM | #3 |
Ok ill give that a shot. Do you think it could be the cai causing this problem.
02-27-2017, 12:11 AM | #4 |
"BEASTM*DE"
How long did you leave the fuse out???I think several members have posted that they had to leave it out over night...Did you start noticing a power loss before the mods, or were the mods on the car when you purchased it???Car should be pulling like a freight train...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
02-27-2017, 12:20 AM | #5 |
I left the fuse out for about 15 hours. No mods on the car when i bought it. I added them. It has been doing this since day 1. I was hoping the mods would help but it might of made it worse.
02-27-2017, 02:40 AM | #6 |
"BEASTM*DE"
My knowledge is limited regarding mechanical issues, I'm sure one of the more knowledge members will see your post and offer excellent advise and get you headed in the right direction...
02-27-2017, 05:52 AM | #7 |
Drives: 2019 ZL1 Join Date: Dec 2016
Could be kr rearing its ugly head. Hard to tell without any data logging or a dyno to see what it is indeed putting out. Also see if your heat exchanger is full to the top. If not iat's are high and timing is pulled like crazy. Also who ported the tb? A bad tb will kill throttle response. What CAI are you using? Some require tuning......
2013 Inferno Orange
A6, bone stock |
02-27-2017, 07:27 AM | #8 |
Drives: 2013 ZL1 Join Date: Nov 2012
Other issue is traction control. If the tires aren't stock sized, traction control can pull timing. When you downshift and hammer it, does the traction control light come on ? If so, disable traction control and try again.
BTW, at 70mph, 3rd gear is where you want to be for maximum acceleration. |
02-27-2017, 07:42 AM | #9 |
Drives: 2013 HWSE Indy Festial #26 Join Date: Mar 2011
Why do you have a ported throttle body and who installed it? I'd look at that first.
There are only so many days in your lifetime. So get out and drive your Camaro...
Dan |
02-27-2017, 07:47 AM | #10 |
Drives: 02 Z06, 95 Trans Am, 2012 ZL1 Join Date: Mar 2012
There was another similar recent thread. He found that he had a very low coolant level in the intercooler/heat exchanger.
Bryan 2018 ZL1 M6
02-27-2017, 08:15 AM | #11 |
Drives: 2013 ZL1 M6 Convertible Join Date: Apr 2013
Throw it in third at 70 MPH and watch her jump!
Mild to Wild Switch, Roto Fab CAI, Big Gulp, Washer Relocation, Ported Throttle Body, Rough Idle Road Race Cam, Supporting Valve Train Upgrade, Dynatech Long Tube Headers Ceramic Coated and High Flow Converters, Injector Dynamics 1025 cc, 22.5%Overdrive Balancer Pulley, Fuel Pump Voltage Booster, Moroso Catch Can.
Jannetty Installed and Tuned. 675 RWHP 630 RWTQ 11.325 1/4 Mile Time @ 124.53 MPH |
02-27-2017, 10:23 AM | #12 |
where in NY are you?
if close to me, stop over and we can data log the car to see what is really going on. |
02-27-2017, 11:19 AM | #13 |
Drives: 2017 HBM Camaro ZL1 M6 Join Date: Feb 2010
02-27-2017, 11:34 AM | #14 | |
1st Gear to 53 MPH 2nd Gear to 79 MPH 3rd Gear to 108 MPH 4th Gear to 140 MPH 5th Gear to 176 MPH 6 th Gear to 223 MPH Just make sure you Rev. Match Gen 5's don't do it by them selves.
