#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Cosmetic modifications (exterior and interior)
AWE Tuning
Old 08-29-2017, 06:05 PM   #1
camex
Drives: Sold
How to remove shark fin antenna?
Anyone know how to remove it?
I want to paint on my antenna but I don't know how to take it off.
camex is offline   Reply With Quote
Old 08-29-2017, 08:07 PM   #2
Pfuqu2ss
Drives: Fuqing car
Pretty sure it's just 3m double sided taped on. Not sure where the actual plug is the though. Probably have to remove the headliner to gain complete access.
Pfuqu2ss is offline   Reply With Quote
Old 08-29-2017, 08:17 PM   #3
travislambert
travislambert's Avatar
Drives: '17 ZL1
It's a pretty big job to remove these. The headliner has to be removed, and according to GM docs, the windshield must be removed in order to get the headliner out of the way enough to gain access to the antenna.
travislambert is offline   Reply With Quote
Old 08-29-2017, 09:34 PM   #4
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
Ouch.
OP, probably best to just have it vinyl wrapped.
Obzen is offline   Reply With Quote
Old 08-29-2017, 11:49 PM   #5
camex
Drives: Sold
Wow, sounds like lots of works.
Thank you for the all reply!
Old 08-30-2017, 01:04 AM   #6
RobertAvitia
BYND GARAGE
RobertAvitia's Avatar
Drives: 17' 1LT Turbo
Not true.. my buddy and I did it before we wrapped his roof. It's fairly simple, just drop the rear headliner and unscrew the antenna from under
RobertAvitia is offline   Reply With Quote
Old 08-30-2017, 01:35 AM   #7
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
This.
Tight squeeze in the back. But doable.
BradfordCamaro is offline   Reply With Quote
Old 08-31-2017, 11:44 AM   #8
jp9109
Clay Sculptor at GM
jp9109's Avatar
Drives: 2016 Camaro 2SS, M6, MRC, NPP
Originally Posted by BradfordCamaro View Post
This.
Yes did the same when I wrapped my roof and a friends. Interior b and c pillar panels need removed then the headliner can be lowered in the rear. Then disconnect the wires leading to it and unscrew the nut (7mm I think) then it pops out. It doesn't have 3M tape holding it down, just a small seal.
It is a tight squeeze but I found removing the folding section of the rear seat gives you a little extra room, just watch out for the latch. And be careful to not pull the headliner to hard, it can crease.
Anything I post or say is purely my personal opinion and not a reflection of GM.
jp9109 is offline   Reply With Quote
Old 08-31-2017, 03:00 PM   #9
camex
Drives: Sold
Thanks!
Old 08-31-2017, 06:20 PM   #10
jp9109
Clay Sculptor at GM
jp9109's Avatar
Originally Posted by camex View Post
Thanks!
No problem, good luck!
Old 04-06-2018, 09:32 PM   #11
Teppo
Teppo's Avatar
Drives: 2018 Summit White ZL1
Exclamation You need 10mm socket....
Hi Folks, Just did this today, couple of things worth noting - Bolt is 10mm, two connectors are wrapped nicely by the good people in Lansing, so that has to be unwound to get to the connector release. The square plastic mount on the bottom does come out through the roof, just wiggle a bit whilst some one pulls from the top.
Thanks for the good start, with out this post I wasn't sure how this was going to go!
Oh, and you were right about that latch!!!
Teppo is offline   Reply With Quote
Old 04-08-2018, 09:11 PM   #12
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
Has anyone relocated the fin inside the car on the back glass?
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
cooper1965 is offline   Reply With Quote
Old 05-02-2019, 02:20 PM   #13
carfish72
carfish72's Avatar
Drives: 2018 Hot Wheels Edition 2SS
How do you physically remove it? The adhesive holding it in place, not the plug. Heat? Mine looks a little off... not perfectly straight from factory. Can it be moved (slightly) without destroying the adhesive? Anyone know?
2018 Hot Wheels Edition 2SS #1581
2014 2SS/RS Red Rock Metallic
2008 Saturn Sky Redline Bluestone
carfish72 is offline   Reply With Quote
Old 05-01-2020, 09:36 PM   #14
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
how big of a hole is in the roof. im putting a cb in the car I have a nice black roof mount antenna. people are going to think my black SS is a police car. I dont need the xm and would be nice if i could put the car back to stock with out any holes in it if i was to sell it. the mount is 3/4" but i could get a 3/8" one.
JCunningham is offline   Reply With Quote
