Old 01-12-2020, 01:28 PM   #1
aaberg
aaberg's Avatar
Drives: 1997 30th conv & 2012 45th conv
How many Torque converter bolts on Camaro 2012 auto?
I need to remove engine L99 from my Camaro 2012 SS and going to take engine up. Therefore I need to separate engine from automatic transmission. I have been told to remove the torque converter bolts and push back the converter a bit to disconnect from crank shaft. After that I can remove the bolts that connect the transmission to the engine.
I have removed 3 torque converter bolts but can't push back the converter at all. Is there more bolts to remove or have I missed anything?
aaberg is offline   Reply With Quote
Old 01-12-2020, 01:32 PM   #2
InFiD3ViL
InFiD3ViL's Avatar
The convertor has 3 bolts. I couldn't budge mine until I got the bellhousing bolts out too, then it seperated fine. You should not be able to push the convertor back very far at all. The mounting pads on your convertor may have rusted or seized to the flywheel. You are not going to be able to push it back far enough to disconnect the convertor hub from the crank with the engine still connected. When I did mine, the engine did NOT want to separate from the transmission very easily. It took a lot of lifting and dropping of the engine hoist in tiny amounts and different angles to get them free because of the bellhousing dowels. Just take your time and be careful not to force anything so you don't damage the TQ convertor hub.
I am assuming you are leaving the transmission in the car.
Old 01-12-2020, 02:17 PM   #3
aaberg
aaberg's Avatar
Thank you for your answer! Yes, I will leave the transmission in the car.
Old 01-12-2020, 03:18 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
A little recommendation since I know you are trying to do things right.
I used the ARP Pro Series Flexplate Bolt Kit 244-2901 and ARP Torque Converter Bolt Kit 230-7304 for reassembly. I figured the cost was very low for piece of mind. I am not sure if these links will work for you, but just so you can see the part numbers and US cost. They shouldn't be that much more expensive for you. It cost me around $40 US total at the time. I couldn't figure out if the stock bolts were reusable, so this was the safest route for me.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 01-12-2020, 03:51 PM   #5
aaberg
aaberg's Avatar
Thank you InFiD3ViL! Yes, teh bolts are self locking and must be replaced with new. the links works fine.
Another issue I have (I will post an new thread) is what cam kit to buy. I don't want to build a racer - 400 hp is fine. And I want to keep variable valve timing (VVT) and components of the Active Fuel Management (AFM) system.
Old 01-12-2020, 04:15 PM   #6
aaberg
aaberg's Avatar
Update: Link to my tread: https://www.camaro5.com/forums/showthread.php?t=568174
Old 01-14-2020, 02:22 PM   #7
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
My 2010 had 3.
I feel for the next guy who has to get them out. (which might be me )
I used red locktite and DIPPED those ****ers in it.
Old 01-14-2020, 02:27 PM   #8
Sxren_Camaro'13
SEAHAWKS FOR LIFE!!
Sxren_Camaro'13's Avatar
Drives: '13 Mod Camaro LS
remember his is a diffrent gen camaro
Sxren_Camaro'13 is offline   Reply With Quote
Old 01-14-2020, 02:53 PM   #9
InFiD3ViL
InFiD3ViL's Avatar
Huh? He is asking about his 2012 L99 SS, not the one in his profile pic..
Old 01-14-2020, 10:39 PM   #10
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 01-17-2020, 12:16 PM   #11
Sxren_Camaro'13
SEAHAWKS FOR LIFE!!
Oh...
