02-20-2012, 05:38 PM | #1 |
Hasbin of Stock Bottom HP
Pedders Drop Springs
Anybody got these on a set of 22's. I had them put on my car I don't think the front ever really dropped. it sits much higher than the rear of the car.
Dunno if its just in my head or what? |
02-20-2012, 06:46 PM | #2 |
Drives: 2020 Satin Steel 2SS Coupe Join Date: Jan 2011
It does look like it sits higher. Were the front bushings indexed?
02-20-2012, 07:00 PM | #3 | |
Drives: Camaro Justice Join Date: Jun 2007
We use mm because it is direct with no fractions. i.e. 660mm on the LF and 663mm on the RF = 3mm difference. If there is a significant side to side variance, turn the car around and measure in as close to the exact same positions all four wheels were in. Some times the surface we measure on looks level, but isn't. Please post the measurements. |
02-20-2012, 07:04 PM | #4 | |
02-20-2012, 07:14 PM | #5 |
The rear seems a bit low, but pictures can be deceiving and why we measure. Is there anything unusual about your Camaro i.e. You have a gazillion watt rack of amplifiers in the trunk or you replaced the engine with a fluxcapacitor they weighs only 3 pounds OK, end of jokes. Is there anything unusual about your Camaro?
02-20-2012, 08:42 PM | #6 | |
But no nothing out of the ordinary really, mixed up the springs for the front/rear, I doubt it. I'm stumped. I'll be measuring though, anything I should take into account for the 22" wheels. 265/30/22 Fronts, 305/30/22 Rears |
02-20-2012, 08:49 PM | #7 |
02-20-2012, 09:31 PM | #8 | |
265 x 30% = 78mm sidewall height, 78 x 2 = 156mm tire height (minus wheel diameter) 305 x 30% = 91.5mm sidewall height, 91.5 x 2 = 183mm tire height (minus wheel diameter) 183 - 156 = 27mm difference in overall front/rear height It could be that with less sidewall on top of the wheel, it creates more space between the front tire and wheelwell, giving the perception that the front end is higher when it's actually the same. Taking a second look at your photo, it looks like if you added about 1/2" of sidewall to your front tires it would look perfect. A 265/35R22 would even things out pretty good.
02-20-2012, 09:46 PM | #9 | |
02-20-2012, 09:47 PM | #10 | |
We are expecting 660mm ride heights with 20s so with 22s (50mm larger wheels) we add 25mm to 660 expecting 685mm. If we have before ride heights I could tell you almost exactly what your ride should be because we could compensate for build tolerance i.e right front 715 on 22s and the left front 710mm. If the new ride height after alignment is still off 5mm it is a pretty fair guess that the variation is in the body work. We'll get measurements and I should have asked for alignment specs as camber differences creates ride height variations. My post just isn't as cool without the math |
02-20-2012, 10:10 PM | #11 | |
I really should have just got the coilovers during the jingle jangle sale Thanks a bunch. |
02-20-2012, 10:14 PM | #12 |
Thank YOU for choosing Pedders. We appreciate your business. Welcome to the PEDDERS NATION!
02-20-2012, 10:53 PM | #13 |
Drives: 2011 2SS Synergy Green Join Date: Nov 2011
Hmm I always read that 1.5" was too low for the rear and I see that the Pedders are 1.4" but I know many people run these springs. Are there any unseen issues with this, Pete?
02-20-2012, 10:57 PM | #14 |
Have not had a single report of any type of issue with strut life and we have had these on customer cars for quite some time.
Similar Threads | ||||
Pfadt Race Engineering Lowering Springs Improve Looks And Performance. | Apex Motorsports | Suspension / Chassis / Brakes | 341 | 02-02-2014 11:52 AM |
BMR 1.4" drop springs, sway bars, pro bushing kit, trailing arms, toe rods install. | SUX2BU | Suspension / Brakes / Chassis | 22 | 05-08-2011 06:27 PM |
Anyone with before/after pics of Pedders springs? | caverman | Suspension / Brakes / Chassis | 17 | 04-10-2010 04:05 PM |
