Gen5DIY
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 07-27-2013, 08:31 PM   #1
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
17" Weld RT-S wheels fit the ZL1 .
There are varying accounts to whether or not 17" Welds fit on a ZL1.
I purchased a used set prepared to make them work either way.
I went to the track last night and finally got an opportunity to try my slicks and skinnies on my ZL1 with stock suspension and driveline. The 17x5's bolted right up with zero modification. The 17x10's rears bolted right up with zero modification. The rears are close to touching the lca but there is clearance. I made four passes from 1.49 to 1.67 60' launches. The painters tape I put on was untouched. The paint on the lower control arms were unmarked.
Edit: I forgot that I tied the Ebrake cable back when I purchased my 18" wheel set up back in the spring.
****UPDATED****please read****
I have now made 15-20 passes and last night the driver side wheel came in contact with the bolt for the stabilizer bar and the LCA. I guess my suspension has softened up just enough over the summer to be the difference. It will be an easy fix. The head of the bolt for the stabilizer bar will have to be ground down on one side and a small dime size dimple put in the LCA to get the clearance. I apologize for the misleading title but I can't change it.
Trackman is offline   Reply With Quote
Old 07-27-2013, 08:41 PM   #2
John Deere Racer
John Deere Racer's Avatar
Drives: 2013 zl1 m6
Nice !!!
2013 ZL1 M6 black on black 10 spokes
592rwhp 616rwtq bolt ons only
www.mikenorrismotorsports.com
Www.lgmotorsports.com
John Deere Racer is offline   Reply With Quote
Old 07-27-2013, 08:41 PM   #3
John Deere Racer
Drives: 2013 zl1 m6
What tire u running ?
Old 07-27-2013, 08:50 PM   #4
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
How much do you weight?
Old 07-27-2013, 08:54 PM   #5
John Deere Racer
Drives: 2013 zl1 m6
M6 or a6?
Old 07-27-2013, 10:08 PM   #6
Trackman
Trackman's Avatar
Was around 210 but the summer beer program is ballooning those numbers.
Old 07-27-2013, 10:10 PM   #7
mlee
www.CamaroFest7.com
mlee's Avatar
Ha Ha... cool because my summers are longer than yours and I'd be carrying more weight. Thanks for the great info.
Old 07-27-2013, 10:11 PM   #8
Trackman
Trackman's Avatar
My A6 is 4470 with a 1/2 tank of fuel in a street set up. So probably 4400 with Welds maybe.
Hoosier 28x10 on the back.
Old 07-27-2013, 10:38 PM   #9
mlee
www.CamaroFest7.com
mlee's Avatar
Weight in the drivers seat makes a difference when you're trying to clear the LCA's.
Old 07-27-2013, 10:41 PM   #10
LS1 Fun
Drives: 2013 ZL1
good info... any pics?
1974 Cadillac Coupe DeVille
2002 Camaro Z28 A4 | 10.80 @ 131 | 383ci, D1SC, 4L80E, 9"
2013 Camaro ZL1 A6 | 12.62 @ 113 | Stock *SOLD
2017 Lexus GS350F
LS1 Fun is offline   Reply With Quote
Old 07-27-2013, 11:10 PM   #11
Trackman
Trackman's Avatar
The wheel picture is a little deceiving. Not quite as tight as it looks.
Old 07-27-2013, 11:14 PM   #12
John Deere Racer
Drives: 2013 zl1 m6
Looks good
The black 1s would look tits though
Old 07-28-2013, 11:21 AM   #13
inferno camaro
inferno camaro's Avatar
Drives: 2010 camaro pace car, 2008 cts bl,
I agree you should get black ones. (and sell me yours)
Mods, 2r max cam, ls3 conv,kooks lt w/hf cats,kooks street sleeper cat back with magnaflow res x-pipe, roto fab cai, v-max TB, vigilante 3700 stall, 3.70 LPE, 442hp/392tq, Mike Norris Tune 11.71@116.24 1.63 60' m&h DR's
inferno camaro is offline   Reply With Quote
Old 07-28-2013, 02:25 PM   #14
*007
Drives: Getaway Special
17 x 5"
Can you provide the exact rim specs on the front (fact they fit over calipers is great!), AND the exact tire you used? It looks like it could make a good "spare tire donut". I bet many would like to have one for that purpose instead of just for drag racing. It would be nice to have the numbers to insure, if ordered, one would get exactly what you have! I am also wondering, in a pinch, if the front skinny would fit and be able to be used on the back for a short period of time to avoid having to call a tow truck driver in the event of catastrophic tire failure.
Another thought... might Weld make a cheaper version of the rim from your knowledge (plain black steel) that would suffice and not be a $400+ rim!??
Thanks for any input on this and appreciate the feedback!
Tire setup looks great for drag racing too!
Sip:
*007 is offline   Reply With Quote
