Caryle Racing
Old 06-01-2017, 05:12 AM   #1
15rs/ss
Drives: 2015 Yellow 2SS LT Z28 cai tune
Data logging
Can someone here please tell me how to data log for my transmission and wide band? I have hp tuners pro. do i have to keep the laptop in the car?
15rs/ss is offline   Reply With Quote
Old 06-23-2017, 02:46 AM   #2
ZL1C7
ZL1C7's Avatar
Drives: 2015 ZL1/1970 GTO 455HO
Unfortunately Its not easy enough where someone can just give you an answer. There are parameters that need to be set up first. If you truly installed an aftermarket wideband there is a separate process for that also. Once everything is set up correctly it is possible to record with the pro and do the playback on the laptop later but until you are pretty familiar with all of this you are better off having a co-pilot and the laptop.
ZL1C7 is offline   Reply With Quote
Old 06-23-2017, 05:01 AM   #3
Superman09
Account SNAFU
Superman09's Avatar
Drives: 13 Tahoe 79 Scout II 15 1LE
What ZL1C7 said. I'm still learning tuning but from what I have read so far that's pretty good advice. If your looking for a wideband that plays well with HP tuners I am selling an AEM 30-2310 that works very well. Sorry for the shameless plug. Best of luck with your tuning endeavours.
Sent from my VS995 using Tapatalk
Superman09 is offline   Reply With Quote
