Cold Air Inductions
Old 06-23-2017, 06:13 PM   #1
RandRSS
RandRSS's Avatar
Drives: 2010 SS Camaro Eforce SC
Intake air temperature?
Can anyone tell me what "normal" IAT is? I just started doing some data logging and noticed my IAT is about 150 degrees f. I saw a video on YouTube and theirs on a track was 63! Thanks!
RandRSS is offline   Reply With Quote
Old 06-23-2017, 08:07 PM   #2
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
Depends on your application and what are you doing with the car.If the car idles for 30 minutes in 100F weather with the hood closed,it will be well above 100F. Some forced induction applications,under boost after a 1/4 mile drag run can see 150F after the run.
150F is not normal for normal driving .
AGP Twin Turbo. Fore Innovations Level 4 fuel system.Great fuel economy !!!!
JMI is offline   Reply With Quote
Old 06-23-2017, 08:55 PM   #3
JLGO
JLGO's Avatar
Drives: 2015 Camaro SS convertible L99
Its normal because it's summer. It should go down when driving at hwy speeds.
JLGO is offline   Reply With Quote
Old 06-23-2017, 09:08 PM   #4
QUICRNU
QUICRNU's Avatar
Drives: 2010 ABM SS/RS A6
I have the LSA Blower on my 2010 with the Bypass Valve, and my IAT is taken from inside the blower hood. Mine hit 140 degrees at the end of the 1/4mile on 10lbs boost the whole way..... so I guess.... 150 in a NA car with the MAF in the intake tube seems high.
What Intake are you using? Stock?
The heat can build up QUICK under the hood.... and sitting still the numbers get extreme, but if you are cruising along... the IAT would Ideally be within 110 to 120% of ambient. Sitting still... all bets are off, especially without Hood vents.
2010 ABM SS/RS A6 w/Mojave
Build Thread - http://www.camaro5.com/forums/showthread.php?t=481043
QUICRNU is offline   Reply With Quote
Old 06-23-2017, 11:42 PM   #5
RandRSS
RandRSS's Avatar
I did not think of SC or NA as having an effect on IAT. I thought the sensor was in the intake tube. So I am Eforce SC BUT, this temp was during a short drive down the hwy., on a 59 degree day. Car was previously warmed up, data log was only 6 minutes 42 seconds.
