BORLA
Old 07-09-2017, 02:20 PM   #1
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
Exclamation Need HELP setting up AEM Widebands AFR's in HP Tuners
OK folks, help me out here. I need help setting up two AEM Widebands AFR's in HP Tuners.
I have two of these that are supposed to be plug and play pretty much:
http://www.aemelectronics.com/?q=pro...nd-uego-OBDII#
I did everything in this video:
https://youtu.be/ozJz-pNFCuo
But it would only detect 1 sensor out of the two. When I saved that sensor, no gauges show the data.
To top it off, when I saved that one sensor, I lost all my channels and custom graphs like LTFT+STFT, etc.
Thanks.
2010 Cyber Gray Camaro 2SS RS
Cold Air Inductions CAI
JRE CAI Scoop + RotoFab Washer Bottle Relocation Kit
Kooks Ceramic Coated Signature Series Stepped Headers w/AFR bung
Kooks full 3in exhaust
Texas Speed VVT 3.2 cam kit
Texas Speed DOD Delete
Texas Speed 1.72:1 Ratio LS3 Steel Roller Rocker Arm Set w/ Roller Tip
AEM X-Series OBDII Wideband Gauges (PN#30-0333)
DSX Tuning Flex Fuel Kit
HP Tuners VCM Suite (Tuning help by http://StreetnTrack.net member gammey4)
John_C is offline   Reply With Quote
Old 07-09-2017, 02:25 PM   #2
John_C
LSx FTW!!!
John_C's Avatar
My setup at the moment is this. Welded in 2 bungs and added the widebands:
Old 07-09-2017, 03:46 PM   #3
QUICRNU
QUICRNU's Avatar
Drives: 2010 ABM SS/RS A6
I know you have to set the 2nd gauge to 7 and then OBDII to 2...seems strange it wouldnt recognize it. Maybe try a different #
In HPtuners you did the drop down while car was on for REpolling channels?
2010 ABM SS/RS A6 w/Mojave
9.926@137.67 - 1.401 60' ft
Build Thread - http://www.camaro5.com/forums/showthread.php?t=481043
QUICRNU is online now   Reply With Quote
Old 07-09-2017, 09:51 PM   #4
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
There is only one O2 sensor in the picture. Do you have you leave one out of the picture?
UNRIVALED SS is offline   Reply With Quote
Old 07-10-2017, 04:34 AM   #5
John_C
LSx FTW!!!
John_C's Avatar
What drop down are you speaking of and how to setup 2nd sensor as #7?
I did what the video said:
Connect
Re-pull for supported parameters
Add channels
Search for WB EQ
Clicked the 12 yadda yadda under the 1 sensor that picks up
Then right-clicked on sensor in channels
Setup for 14.7:1 (Gas)
Setup for 10ms (100Hrtz)
Old 07-10-2017, 04:35 AM   #6
John_C
LSx FTW!!!
John_C's Avatar
Look again. I only opened 1 of 2 boxes.
