06-21-2011, 10:38 PM | #1 |
Slow Turtle
Urethane filling subframe inserts
Doing mine this weekend, surprised there aren't more people doing it this way. It's cheaper then buying inserts, and does the same thing. Downside is you have to completely remove the subframe to do it.
06-21-2011, 10:40 PM | #2 |
Slow Turtle
http://www.amazon.com/Auto-Products-.../dp/B000CQ6IG2
Most parts stores stock it as well. I got two tubes, should be plenty to do the subframe and diff bushings. |
06-21-2011, 11:28 PM | #3 |
Slow Turtle
I'll even take a few pictures to document.
06-22-2011, 12:34 AM | #4 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
We use to do this to our motormounts, back in the day. Should be fine as long as you give it plenty of time to set up.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
06-22-2011, 12:37 AM | #5 |
Slow Turtle
It's a 24-48 hour cure time. Will have several weeks to sit, so it's all good
@Motor mount comment : I've done several tired old motor/tranny mounts on several cars with this stuff. Brings them back to life for sure and limits motion greatly. Cant beat it for the cost |
06-22-2011, 07:49 AM | #6 |
Search Ninja
I mentioned doing this in a thread not long ago but no one replied to it. Seems like a feaseble alternative to doing the inserts and as you mentioned, considerably cheaper. The only issue I see is the possible hassle of getting it out if you deside to go with full bushing replacements.
06-22-2011, 08:50 AM | #7 | |
Drives: the 2nd amendment home Join Date: May 2008
Seems to be more of a repair than a solution, but let us know how it works for you.
-- Benjamin Franklin |
06-22-2011, 09:15 AM | #8 |
Drives: 2010 Transformer 1SS Camaro Join Date: Nov 2009
If I had to remove the subframe anyway, I would just replace the bushings with polys.
06-22-2011, 09:23 AM | #9 | |
I'm not totally useless..
You do know that this product is made for windshields etc right? I doubt it will stand up in your application....
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
06-22-2011, 10:43 AM | #10 |
Yep, durability is probably gonna be an issue.
06-22-2011, 11:02 AM | #11 | |
Search Ninja
06-22-2011, 11:39 AM | #12 | |
As long as ALL of the gap is filled AND the proper product is used then maybe. I'm not sure they make a decent durometer material in a "self application" package....
06-22-2011, 01:09 PM | #13 |
Drives: '69 SS Convertible Join Date: May 2009
Not that I would use them again but I got a set of Energy Suspension inserts shipped to my door for $100. That's just a little more than what was mentioned for the cost of doing this.
My personal opinion is that I would use the Engergy before doing this but then again I would suggest saving the money for the Pedders inserts or just do a full bushing replacement. Thats me though.....
Build Journal |
06-22-2011, 01:21 PM | #14 |
Search Ninja
And we all saw how well they worked out for ya, .
Similar Threads | ||||
5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 05:52 PM |
Subframe Bushing Inserts - BMR, Pedders, Prothane, Energy, etc.??? | parietta | Suspension / Brakes / Chassis | 23 | 03-21-2013 08:11 AM |
FS: Brand New Pedders EP1200 Subframe Bushing Inserts | DadsCamaro | Suspension / Chassis / Brakes | 4 | 10-30-2010 07:59 PM |
Subframe Bush Upgrades. From Simple DIYer to Full Race Capable | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 16 | 05-03-2010 09:29 PM |
New to Suspension (look over list please) | Brokenlizrd | Suspension / Brakes / Chassis | 19 | 04-23-2010 11:31 PM |
