05-31-2010, 11:08 PM | #1 | |
2010camaroSS
Drives: 2010 Camaro SS Join Date: Feb 2010
LS3 VS L99
What is the difference between the two? I know the LS3 is the M6 and the L99 is the A6 and the M6 is lighter than the L99. But what is the difference in the engines???
05-31-2010, 11:13 PM | #2 |
CamaroFans.com
VVT Variable Valve Timing and DOD Displacement on Demand for the L99. DOD sometimes called AFM Active Fuel Management is a system that drops the engine to 4 cylinder mode to save fuel. Keeps the L99 A6 at the same gas mileage numbers as the LS3 M6
Now that you have the buzz words and accronyms... search around as there are tons of threads on this stuff... |
05-31-2010, 11:15 PM | #3 | |
2010camaroSS
is the cause to why it makes about 26HP less?
05-31-2010, 11:17 PM | #4 |
CamaroFans.com
Yes pretty much...
05-31-2010, 11:19 PM | #5 | |
2010camaroSS
Thats a little sad:( Otherwise don't they have the same exact engine specs?
05-31-2010, 11:20 PM | #6 |
CamaroFans.com
Yeah... but with some trans tuning the L99 really closes that gap... It's actally a sore subject, and some, like myself, end up tuning out AFM.
05-31-2010, 11:52 PM | #7 |
Drives: 2013 A6 GT 5.0 Join Date: Nov 2009
The reason the L99 makes less power than the LS3 is that GM with all its wisdom decided to put a baby cam in the car. I mean I dont even think the cam has over .500 of lift. The compression is a little lwer too because of valve reliefs but the heads, intake, crank, block, and rods are the same. The only major differences is the lifters, cam, pistons,intake valves and VVT timing chain. If GM had put the same size VVT cam in the L99 then it would have made more power than the LS3 and I could then justify my purchase being 1k more than the Ls3 manual combo.
06-01-2010, 01:27 PM | #8 | ||
2010camaroSS
06-01-2010, 01:57 PM | #9 |
Drives: 2010 camaro ss/rs Join Date: Dec 2009
Everyone is entitled to ther opinion so here is mine. I currently own the manual 6 speed and it has CAI,HEADERS,CATBACK,CUSTOM CAM, SHORT THORW SHIFTER,& CUSTOM TUNE and that adds up 464rwhp and 430rwtq. It's a blast to drive. My problem with the car is I have a hard time launching the car at the track to get good 1/4 times at the track. If i could go back to when i was purchasing it i would probably lean more on buying the automatic. 26 horespower can be made up very easily but the consitency you get out of it in my opinion outways the 26 less horspower! but that doesnt mean without some practice you cant get it done! goodluck!
06-01-2010, 02:13 PM | #10 |
Drives: 2006 Dodge Charger / 2SS IOM Join Date: Dec 2008
yes it would but to do that u would have to change the lifter and springs, deleting VVT and etc on the DOD or AFM cylinders. and if ur going to pay that much to do that u might as well get a better aftermarket cam than the stock ls3 cam.
06-01-2010, 02:23 PM | #11 | |
Drives: SuperSport's Join Date: May 2009
2002 Chevy CamaroSS MN6
'08 Chevy TBSS AWD "DD" Plans : 2013 CamaroSS 1LE |
06-01-2010, 02:45 PM | #12 | |
2010camaroSS
Well I honestly don't mind about deleting the VVT or whatever, thats perfectly fine with me. I kind of was leaning towards getting the LG Motorsports G6X3 cam anyways. Hey BTW does anyone know of a good cam from LG Motorsports to use for a TT setup?
06-01-2010, 02:53 PM | #13 | |
CamaroFans.com
After 3 or 4 runs with timeslips that look like they came off a copy machine... what's the use. Bracket racing here I come... |
06-01-2010, 07:23 PM | #14 |
Drives: Body In White Camaro Join Date: May 2010
Make no mistake the L99 has the potential to make more power across the board thanks to the VVT stuff. Give it time, I believe with a custom TSP camshaft & PRC's new cylinder head castings we'll see 500rwhp A6 L99 cars!!
Just gotta get those stinkin lifters out of that thing!! |
Similar Threads | ||||
LS3 engine specifications | Tran | Wiki | 3 | 10-06-2010 10:56 PM |
LS3 and L99? | black2black10 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 05-07-2010 12:58 AM |
LS3 vs L99 mods | ORANGE U NV | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 4 | 01-10-2010 09:45 AM |
Solo Performance V8 Quantum Axle-Back Exhaust Kit for LS3 and L99 | GOINGSOLO2 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 1 | 12-03-2009 02:01 PM |
LS3 vs. L99 | LS3 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 12 | 01-21-2009 10:39 PM |
