07-18-2011, 11:30 AM | #1 |
Guess my HP?
Okay as many of you know. I have an LSX376 in my car which is rated at 450HP out of the crate.
I'm curious to see what my car will lay down to the ground.. I have XS-Powers full kit. I'm putting on granatelli's cold air intake here shortly. And I have HPtuners, so tuning is no issue. Any guesses on what I should be able to put down? BTW, I have the revised LSX376 which is 10.7:1 compression, not the original that was 9:1. I'm hoping for atleast 400 wheel. |
07-18-2011, 11:38 AM | #2 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Hmmm ... I say with headers, intake and tune = 425 RWHP / 430 RWTQ
Based on what I've seen LS3 do with the same setup ...
07-18-2011, 11:53 AM | #3 |
07-18-2011, 12:52 PM | #4 |
雪の玉
Drives: '22 Z71 RST Silverado Join Date: Feb 2011
07-18-2011, 01:35 PM | #5 |
I will be posting dyno sheets once i'm done..but that could be a month or two
07-18-2011, 01:47 PM | #6 |
ace5.org
You were the guy who threw a pushrod or something through the engine right? So you had to buy a new motor on your own?
Stock...For Now.
07-18-2011, 02:30 PM | #7 |
07-18-2011, 02:55 PM | #8 |
Drives: 2010 Camaro 2SS/RS Join Date: Mar 2008
I read this over in the Vette forum. You might want to read it. The lower compression (made for forced induction) seems to be holding it back NA.
This guy made 403 rwhp with full bolt ons and tuning on his LSX 376. Here's the quote: So I purchased this engine, under the impression it made 450 hp (with a stock style setup (LS3)) Well I have mine set up that way, and after doing some thinking, tuining, and dynoing my car is where it should be with this engine. However, I think they should use their claimed HP numbers and lower them from the crate LS3. Because this motor was built for boost, and is essentially a LS3. Yet the compression ratio is 9:1. Making it have less power. Both have the same size cubic inches, heads, cam, the pistons are forged on the LSX 376 however, and the block is made of iron instead of aluminum. My setup consisted of: 99 FRC with a LSX 376 LSX 376 Long block LS3 intake manifold Kooks 1 7/8 long tubes Kooks off road X pipe Borla Straight pipe Vararam Intake LS3 Water Pump LS3 Throttle Body I did some "bench dynos" and with the claimed 450 HP the engine should have, I guestimated roughly 430 RWHP with the mods.These numbers would be correct if the compression ration was higher. But I believe my best numbers for today after tuning were 403 rwhp 396 rwtq Which would be spot on for a lower compression LS3. Now I just wish GM would market that crate engine like that. Im a little disappointed because of the 450 HP claim. Not saying it is not true, it's just not true with the LS3 configuration or "Production Style" as they claim. Overall I'm happy though, because when I do throw a blower on it will be ready to handle it! |
07-18-2011, 02:58 PM | #9 |
Vroom
With full exhaust and a Cold Air intake I'm guessing 415.
LSX, Boost, 9", TH400
xxxxhp - xxxtrq |
07-18-2011, 03:06 PM | #10 | |
07-18-2011, 03:08 PM | #11 |
Yeah, with that lower compression you should be able to safely turn up the boost. So in the long run, you should be able to make more HP (safely) than if you were running a regular LS3.
07-18-2011, 03:09 PM | #12 |
Especially with the forged pistons.. I'm only going to put 6-8psi through it. I figure that'll be enough to make me smile all day.
07-18-2011, 03:13 PM | #13 |
knows 2 facts about ducks
I'm assuming we are doing this Price is Right style correct? Well if we are, I say 1 rwhp 1 rwtq
07-18-2011, 03:16 PM | #14 |
Similar Threads | ||||
guess what i saw at work today... Bumblebee Camaro from TF3 ! | tmurphycardesign | 5th Gen Camaro SS LS LT General Discussions | 53 | 03-10-2011 08:39 AM |
Well I guess Splash Guards are going on | zerox | 5th Gen Camaro SS LS LT General Discussions | 16 | 12-04-2010 03:13 PM |
Guess that car. | shank0668 | Off-topic Discussions | 32 | 04-10-2010 01:53 AM |
HEY, GUESS WHAT HAPPENED | billmiller8 | 5th Gen Camaro SS LS LT General Discussions | 4 | 02-20-2010 06:07 PM |
2010 Camaro Engine Line-Up Guess | camaro5 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 75 | 04-11-2008 02:25 PM |
