04-15-2011, 10:53 PM | #1 |
Drives: 2SS/RS 6M Join Date: Nov 2009
Anybody install the Pedders Caster alignment bolts
I have had the caster and camber kit from Pedders for a while now and want to put them in this weekend but need to know how much to slot the hole.
I was hoping there was something on the Pedders site but did not see any measurement. The camber bolts are pretty much self explanatory. I know there is some material removal but dont want to take off to much. Thanks
2SS/RS 6M MGW short throw shifter, ADM race cold air intake, Kooks 1 7/8 Headers, Kooks 3 inch exhaust, Pedders rear subframe bushing inserts, Pedders radius arm bushing inserts, Stillen drilled and slotted rotors, "Mike the Powdercoater" yellow powdercoated Brembos, ADV.1 Wheels and Dunlop run flat tires, and VMAX ported throttle body
04-16-2011, 05:35 PM | #2 |
Found some pics from pedders. Would enjoy speaking with someone who has already tackled this mod.
04-16-2011, 06:02 PM | #3 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
How about Pedders or any of their vendor shops?
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
04-17-2011, 03:27 PM | #4 |
I just put these on. Just use one of the washers and turn it to 3 o'clock and 9 o'clock and mark the ends of your slots. I found it easiest to use a 90deg. air grinder and a carbide bit.
2010 2SS M6 CGM LMR cold air, texas speed underdrive pulley and complete stainless exhaust 17/8 headers coated, comp LSR cam, push rods and trunion upgrade, norris catch can, prothane engine mounts, pfadt coilovers, BMR everything suspension, BMR four point strut, MGW billet shifter, barton pistol grip handle, AAC dome and footwell blue, all lights 25% tint, RKsport carbon inlay spoiler, powdercoated calipers, Stoptech stainless brake lines, Hawk HPS pads, West Bend Dyno tune 491rwhp and 465rwtq corrected.
04-25-2011, 09:42 PM | #5 |
Thanks for your reply
Did you remove the radius arms for better access, it looks kinda tight in there!!
04-26-2011, 07:28 AM | #6 |
"Camaro Joe"
you need to lower the radius arm this way you dont damage the bushing
04-26-2011, 08:24 PM | #7 |
Drives: His Wife Crazy Join Date: Jan 2008
Sorry that i missed this thread, i think this was when we were at the fest last week.
You need to pull the arm out of the way, removing it form the car is the best way, but you can do it with it still attached, just pulled out of the way. Using a carbide grinder you can slot the hole fairly quickly, you don't need to slot it towards the rear of the holes, just the front side, as you will not be going more negative with the caster, just more positive. |
04-26-2011, 08:48 PM | #8 |
Been looking for a carbide grinder for my pneumatic angle grinder but have had no luck any suggestions would help where I can pick one up.
Thanks
04-26-2011, 08:51 PM | #9 |
"Camaro Joe"
harborfreight.com, they are pretty cheap and they are a good household grade, i use some of there tools in my shop too so i know they will hold up
04-26-2011, 08:57 PM | #10 |
Any local carquest or napa should be able to help you with that, or home depot/lowes.
Similar Threads | ||||
Hotchkis versus Pfadt Sway Bars | Avalnch | Suspension / Brakes / Chassis | 78 | 05-02-2018 03:26 PM |
Pedders Xa Coilovers and Springs | In stock | Free Shipping | Best Prices | JDP Motorsports | Suspension / Chassis / Brakes | 115 | 02-16-2015 08:42 PM |
Poll -- Camaro vs Mustang Supercar Shootout | JusticePete | Suspension / Brakes / Chassis | 105 | 10-09-2013 02:18 PM |
Better Handling | Tbanks | Suspension / Brakes / Chassis | 30 | 12-15-2010 11:50 AM |
SEMA, Pedders Conference, GS Camaro, New Products | JusticePete | Wheels and Tires Talk Sponsored by The Tire Rack | 25 | 12-01-2008 01:25 PM |
