Old 07-11-2014, 06:37 PM   #1
BillM
BillM's Avatar
Drives: 2014 Convertible Summit White 1LT
Advice on DA Polisher
I've done some research but can't see much difference between the Meguiar G110v2, Griot's Garage 10813STDCRD, and the Shurhold 3101.
I've had my vert since December and don't have any damage to the body, so I don't think I need to do any paint corrections. I'm more interested in it being easier to wax and polish it.
Any suggestions?
Life is good
BillM is offline   Reply With Quote
Old 07-11-2014, 06:59 PM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Polishing = paint correction.
I'd go with a griots 6" if I were you. No idea if that's the model number you posted
[B]
Old 07-11-2014, 07:09 PM   #3
JTruck
JTruck's Avatar
Drives: 2014 Camaro 1LT/RS
The Meg's starts at a lower OPM and maxes as the same as the Griots. The Shurhold has a lower maximum OPM compared to the other two, haven't heard much about Shurholds though. The Shurholds also has a considerably less powerful motor.
I haven't heard anyone go wrong with Griot's.
Detailing is an involuntary obsession.
JTruck is offline   Reply With Quote
Old 07-11-2014, 07:21 PM   #4
DARK AGE 53
DARK AGE 53's Avatar
Drives: 2010 SS
Might be worth looking into a HF DA, http://www.camaro5.com/forums/showthread.php?t=353901 .
POW/MIA - YOU ARE LOST BUT NOT FORGOTTEN IN SOUTHEAST ASIA
DARK AGE 53 is offline   Reply With Quote
Old 07-11-2014, 08:05 PM   #5
jshaf
Montani Semper Liberi
jshaf's Avatar
Drives: 2011 Black 2SS/RS w/ IOM stripes
have had a Griot's for 4 years, no issues and it just does the job no matter what I need it to do.get a variety of pads, I use the Orange pads the most.
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint
jshaf is offline   Reply With Quote
Old 07-12-2014, 04:45 AM   #6
KBsSS
KBsSS's Avatar
Drives: 2013 Corvette 2LT
Any suggestions?
My 2 cents it that you need to do a paint correction. wash , Iron X , clay, polish and seal or wax.
I have a summit white Camaro and when I did the Iron X you should have seen all the purple spots from contamination.
Doing this will give your a great shine. BTW I have a 3" and 6" Griots and I use the micro-fiber pads.
KBsSS is offline   Reply With Quote
Old 07-13-2014, 01:54 PM   #7
Angelo@Autopia
Angelo@Autopia's Avatar
Drives: 2014 Ford Focus ST
This works for all DUAL-ACTION ORBITAL CAR POLISHER'S
A dual-action car polisher (often called "random orbit polisher" or "orbital polisher") is a machine that operates by orbiting the polishing pad around a center spindle while the pad freely spins on its own axis. A counterweight on the opposite side of the center spindle dampens vibration for smooth operation.
The tool head action, often called orbital, prevents the creation of holograms (symmetrical buffing marks), paint burns and other forms of paint damage often associated with high-speed buffing machines. When used with proper care, the design of the Porter Cable 7424XP Polisher virtually eliminates the possibility of paint damage.
The polishing action of the Porter Cable car polisher and other dual-action polishers closely mimics that of circular hand polishing. Imagine being able to make 2,500 to 6,000 tight hand circles in a single minute and you'll have a pretty good idea of how the Porter Cable 7424XP Polisher does its job. It works just like your hand, only at super-human speed!
Some people have defined the action of a dual-action orbital polisher as "jiggling", but this is not the case. The head freely rotates on a bearing and orbits around the centerline driveshaft. Rotation is a free-wheeling action of the backing plate spindle caused by the orbiting head. This "dual-action" is where the polisher gets its nickname.
If you have previously owned a random-orbit car polisher that made a lot of racket, but did little else for your car�s finish, you will Porter Cable 7424XP Polisher "professional grade" machine. Most consumer car polishers do not have enough power, have a very small orbit (often less than 1/4 inch), and have limited accessories. The Porter Cable polisher is the first machine to shatter these limitations.
THE POWERFUL ORBITAL POLISHER DESIGN
How a Dual-Action Polisher Works
Most dual-action polishers use an offset spindle that freely orbits around the center shaft. A counterbalance weight dampens vibrations.
The orbiting head action, combined with a high-speed motor offers the same gentle polishing action as your hand, only at super high speed.
ORBITAL POLISHER BASIC FEATURES & OPERATION
The Porter Cable 7424XP Dual Action Polisher has a powerful motor for its size (3.7 amps). If you don�t have a garage, you can run the polishers off of your car battery using a 750+ watt power inverter. Porter Cable 7424XP Polisher uses a standard 5/16-24 spindle, so a lot of different attachments will fit.
The Porter Cable 7424XP Polisher measures about 10 inches in length and weigh about 6 pounds with a backing plate and pad attached.
A reversible side handle makes the Porter Cable 7424XP Polisher very easy to hold and control, even when working on vertical surfaces. Use of the side handle is a personal preference. It adds a bit of safety, but people with large hands may find it just as easy to grip the polisher by the head with a single hand.
The machine functions at 2,500 to 6,000 operations per minutes (OPM), controllable by a thumbwheel on the rear end of the machine. The OPM measurement is used instead of revolutions per minute (RPM) to distinguish the difference between orbits and center shaft revolutions. At 6,000 OPM, the UDM by Porter Cable car polisher does a lot of work.
Comparatively, the Porter Cable 7424XP Polisher orbital polisher comes fully equipped with a Velcro backing plate and a functional foam polishing pad. Ultimate Detailing Machine also offers a fully equipped model with a full compliment of foam polishing pads and microfiber bonnet.
Features
Polisher Feature Specification
Power 120 VAC, 50-60 HZ/120 VDC
Motor 110 volt, 3.7 amp
No Load Speed Electronic variable speed 2,500-6,000 rpm
Spindle Thread Accepts 5/16 - 24
Weight 5 1/4 LBS
Backing Plate 4.75" diameter, flexible, with hook & loop (Velcro) backing
Changing polishing pads and backing plates is easy. You use the flat spindle wrench supplied with the car polisher to hold the spindle and rotate the backing plate counter-clockwise to loosen or clockwise to tighten. When tightening, it is not necessary to turn the backing plate more than � turn once it has initially seated. Do not over-tighten. Snug is just fine.
Changing backing plates is easy. Use the flat wrench provided with your Porter Cable 7424XP Polisher to hold the center spindle and unscrew the backing plate with your hand. Do not over-tighten.
For safety reasons, do not operate your dual-action polisher unless the pad is flat on the work surface. That means you both start and stop the machine while it is resting flat on the surface of the car. If you�re not going to follow this safety precaution, please wear safety glasses.
OPERATING A DUAL-ACTION ORBITAL POLISHER
To operate the machine, follow these simple car polisher operating instructions:
Your car must be freshly washed and dry. Do not buff on a dirty finish.
Work in an area with good lighting. Overhead fluorescent or halogen lighting is best.
Remove all rings, watches, bracelets, belts and other items that will scratch your paint.
Wear an apron to protect your clothing and the paint finish.
Adjust the machine speed to 3 or 4 on the thumbwheel. This is a good starting point.
With the machine switched off, apply a small amount of polish, cleaner or wax directly to the polishing pad. There are two good methods that seem to work. Squeeze out a complete ring of product about 1 inch in from the outside of the pad, or squeeze out an �X� of product across the pad.
Dab the pad in 3-4 spots around the area to be polished, cleaned or waxed to distribute the product.
Position the polisher flat on the work surface, get a firm grip and switch it on with your thumb.
Move the car polisher back and forth (east/west) in a slow, sweeping motion, overlapping each pass (by 50% of the pad width) with the previous, and then switch your pattern to up and down (north/south).
It is not necessary to apply more than a pound of pad pressure. Allow the car polisher to work under its own weight.
Use a clean pad with each product. Do not mix products on a pad. If a pad is not dirty, you may store it in a Ziploc baggie for future use. Be sure to label the baggie or the pad.
If a pad becomes caked with product, use a nylon or horsehair detailing brush to clean the pad.
Sounds pretty simple, doesn�t it? It really isn�t difficult. Within a few minutes of use, most people are very comfortable operating the machine.
MAINTAINING & IMPROVING PAINT GLOSS WITH CAR POLISHER
It is polishing, not waxing, that offers the most improvement in the overall appearance of paint. If you wax over bad paint, it�s still bad paint. When you polish bad paint (paint with scratches, heavy oxidation, swirl marks, stains, water spots, etc.), you remove the bad paint to reveal a fresh finish. Obviously you can only do so much polishing before you wear out (thin or completely remove) the paint, so only polish as much as necessary to maintain healthy paint.
Buffing pad and polish makers create products with different levels of aggressiveness to make your polishing tasks faster and easier. You can use an aggressive pad and polish combination to quickly remove paint defects or severe oxidation, but it won�t reveal the full gloss potential of your paint finish. Just like polishing a jewel, you must use several grades of car polish to bring out the final radiance.
If your paint is new or like new, it is not necessary to use heavy abrasives. You can use very mild pre-wax cleaners and glazes to maintain the factory finish or create a finish that glows like a gem. To do so, use a fine polish and a foam polishing pad, and work the polish in with a light touch until most of the polish residue is gone. Remove the remaining polish residue with a quality buffing towel. Fine polishes won�t take a lot of heat before they cake up and clog your pad, so don�t apply pressure to the machine. Allow the pad and polish to do the work.
Some polishes respond well to a microfiber buffing bonnet, while others do not. If you're using a polish that is not buffing out clear, try doing the final buff out with a microfiber bonnet over a clean pad.
PRACTICE MAKES PERFECT
While the Porter Cable 7424XP Polisher is a very easy car polisher to master, practicing on an older car with an imperfect finish is the best way to learn. You should experiment with a variety of polish and pad combinations until you learn how to achieve the best results.
There is no silver bullet combination of pads and polish. How you use the machine, your climate, paint hardness, paint color and other issues will all factor into the final results. Don�t get frustrated if your initial experience is not perfect, as the smallest change (a different pad, polish or speed) can make a huge difference.
CAR POLISHER SUMMARY
A dual-action car polisher makes polishing easy and allows anyone to create a stunning finish or restore a badly worn finish. All it takes is a little practice and the right selection of pads and polishes.
Old 07-13-2014, 02:23 PM   #8
FilibustaRhymes
FilibustaRhymes's Avatar
Drives: SS
been using a Porter Cable for years and love it. No idea if it's the "best" but it works.
FilibustaRhymes is offline   Reply With Quote
Old 07-13-2014, 02:43 PM   #9
JTruck
JTruck's Avatar
Originally Posted by Angelo@Autopia View Post
copy/pasted essay
Old 07-13-2014, 04:30 PM   #10
CamaroDreams07
Drives: Slow V6
Originally Posted by JTruck View Post
Doesn't he make you just not want to shop there? His posts rarely have anything to do with the thread.
I miss Todd.
[B]
Old 07-13-2014, 05:00 PM   #11
JTruck
JTruck's Avatar
I miss Todd.
Very much. The OP asked about differences between three polishers and was given a dissertation on how to polish and why it's good (I think, didn't bother to read it).
Todd's posts were personal and well-thought out, where'd he go?..
Old 07-13-2014, 05:49 PM   #12
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Out of the 3 you posted, I'd go Griots 6in. Another good choice is the PC 7424XP. I won't give you a dissertation about it but it just plain works. When buying it alone, it typically doesn't come with the 5in velcro backplate so figure another $15 or so into your cost. That brings the cost up to right where the Griots is. Both are excellent machines and are less expensive than the other ones you posted. There's a reason they are the most common DA's on many detailing boards, and it's not just price.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 07-14-2014, 09:45 AM   #13
DylanVK
Drives: a few
Having been up close and personal with both the GG and the Shurhold (plus other tools coming from the same manufacture in China) I'm fairly positive they're the same tool, just with slightly different plastic cases.
My vote is go with the one that offers you the better price and warranty for your needs... functionally I'm about 99.9% sure they offer the same internals and performance. Same goes for the DAS-6 not that many of them make it over here from Europe.
1967 C/10 PROJECT TRUCK | DETAILING EXPERT | CRAFT BEER ENTHUSIAST
DylanVK is offline   Reply With Quote
