07-24-2013, 01:15 PM | #1 |
Heat exchanger replacement
I am swapping out my intercooler heat exchanger tomorrow for a cooler logic one. I have read in the owners manual that draining and refilling this system is difficult and calls for a special procedure. Does anyone who has swapped out the coolers have any tips on draining and refilling?
08-18-2013, 02:13 PM | #2 |
Romanian Outlaw
Drives: 13 ZL1 , 14 Silverado Crew Cab Join Date: Apr 2010
+2
[/SIGPIC]2013 Camaro ZL1 M6
08-18-2013, 02:30 PM | #3 |
Drives: 2017 ZL1 A10 Join Date: Sep 2009
This is what worked for me. Once you have the cooler in place and both hoses filled with fluid, (yes, manually fill both hoses) blow air back the opposite direction just enough to push the air bubble that is in the pump out. then hook everything back up, and verified that the pump in circulating fluid.
2017 ZL1
A10 Redhot with stripe |
08-21-2013, 08:24 AM | #4 |
I followed GMs procedure which is to fill thru the filler cap until its fill and the bubbles are out then run car for one minute to let more bubbles out then add more coolant. Repeat a whole bunch of times! Repeated the procedure the next morning and the next! I just ordered the resevoir from D3 performance engineering so that should make filling much easier. They are doing a group buy right now for a pretty good price.
08-21-2013, 11:41 AM | #5 |
Drives: '12 ZL1 #1609 Join Date: Feb 2010
I got my order in for this and the HX from the groupbuy TripleBlkZL1 helped arrange.
Life is too short to drive cars that suck.
My build Thread |
08-31-2013, 09:46 AM | #6 |
Romanian Outlaw
Does it use the orange antifreeze ?
08-31-2013, 09:54 AM | #7 |
Drives: 05 GTO / JETTA TDI Join Date: Jan 2012
I have done a few of these, Dexcool.
I use a funnel with an adapter from Home Depot so it fits in the factory fill. Keep a little coolant in funnel so air can still get out. Remove pump relay and jump with a fused wire on/off on/off (thats with the engine off). Then check again next day. |
08-31-2013, 02:08 PM | #8 |
Romanian Outlaw
I've been doing it with engine on.. So take out fuse and to it that way.. I just installed a heat exchanger with a bleed valve so it suppose to shoot a solid stream to b good correct? Cause its still shooting bubbles
08-31-2013, 04:36 PM | #9 |
No reason to have car running, the relay is under the hood fuse box. Diagram is on the relay or find the hot terminal with everything off then go diagonal across to pump terminal. Use a small fused wire if your not sure.
You can use HPT to run pump if you have it. I like having a small funnel attached to the fill so you have extra fluid and get all the air out. IMHO you should have a reservoir, filling through that pee hole sux. |
08-31-2013, 04:42 PM | #10 |
Drives: 2012 ZL1 Join Date: Dec 2011
I agree. Put a reservoir on and the filling and bleeding procedure is easy as can be.
2012 CTF ZL1-stock
2012 ZL1 (sold) JRE 75rwhp kit catless ported lsa TB 11.04 @ 128.35 on hoosier drs and skinnies @ PRP with 1100DA |
08-31-2013, 06:21 PM | #11 |
Romanian Outlaw
I got the Katech h/x and it has a bleeding line so what I did was blow air in the tank till the line shot a straight steam .. Think it worked?
