05-22-2014, 10:26 PM | #1 |
Whats the point of A.F.M?
Active Fuel Management (afm) drops the cylinder count from 8 to 4 when doing just everyday things, but this feature also takes away about 26hp and about 10 lb of torque. I understand that is ment to save you money on gas. However engines with this feature have a estimated mpg of 24 and the ones without it are estimated at 24 as well! So how does it help?
Sent from my SCH-I545 using Tapatalk |
05-22-2014, 10:29 PM | #2 |
Drives: 12 Boss 302 Join Date: Sep 2009
If automatics didn't have it, they would go into the gas guzzler tax range. That would hurt GM's CAFE, and your wallet.
The biggest mistakes in life come when you know exactly what you are doing.
05-22-2014, 10:30 PM | #3 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
It offsets the advantage of a manual transmission for FE. But the bigger advantage is it helps avoid the GG tax with the automatic in the Camaro.
05-22-2014, 10:40 PM | #4 |
KaBoom1701
To passify the left wing ecofriendly hippies....
Mods:
05-23-2014, 11:47 AM | #5 |
Chu no guat a hasa is?
Drives: 14 Jeep G Cherokee Overland HEMI Join Date: Jun 2011
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
05-23-2014, 01:41 PM | #6 |
Drives: 2015 Z/28 #533 Join Date: Jul 2012
05-23-2014, 02:24 PM | #7 | |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
05-23-2014, 03:06 PM | #8 |
Wind Rider
Drives: ZL1 19 White; Jeep 5.7 GC 15 Join Date: Jan 2010
Im not Gray any more !!
05-25-2014, 06:37 AM | #9 |
Drives: 2010 M6 2SS Join Date: Mar 2011
This statement is untrue. The 26hp/10ft*lb difference is due to the engines being different. Even without AFM the power difference is the same. The L99 (auto/AFM) has lower compression and a different camshaft than the LS3 (manual/no AFM) has.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension |
05-25-2014, 06:13 PM | #10 |
Drives: 1999 Trans Am Join Date: Jul 2009
I've been messing with it on my personal vehicle's. Tuned in correctly you can get 2-3mpg more on avarage BUT I see oil consumption problems when I have it tuned for that.
Taking it out,shutting off and getting a good tune you will average more mpg than having it on. GM engineers do a real good job at tuning these vehicle's in but I do not understand why they leave so much on the table. I'm thinking they tune more for green house gasses. |
05-25-2014, 06:45 PM | #11 |
Is the 26hp a noticeable differents?
05-25-2014, 08:06 PM | #12 |
Drives: 2014 2SS/RS Join Date: Jan 2014
I turn off the TC, and I have enough power for me!
Not planning on racing however... I just want a good looking car that has plenty of power and sounds like it.
05-25-2014, 08:58 PM | #13 | |
The L99 car with any old driver will beat most LS3 cars down the track unless they've got some of the best drivers.
05-26-2014, 04:49 PM | #14 |
Want to know why it has lower compression and a different cam/vvt? AFM.
