Old 07-09-2020, 10:56 AM   #1
samman11
Drives: 2011 Camaro SS Convertible
3.91 installation at dealership
A lot to remove. I stopped in halfway through my 3.91 gear installation. I'm glad a professional is doing this work.
samman11 is offline   Reply With Quote
Old 07-09-2020, 12:14 PM   #2
SSEssence
Instagram: Sangstah
SSEssence's Avatar
Drives: 2019 Camaro 1LE
What was your rough cost estimate? Thanks!
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold
Follow the build https://www.camaro6.com/forums/showthread.php?t=612717
SSEssence is offline   Reply With Quote
Old 07-09-2020, 01:19 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
Yeah, that's what I am interested in. The cost at a dealership.
Old 07-09-2020, 05:04 PM   #4
MeanV8
Drives: Chevy Camaro SS, Chevy Corvette,
GPI is installing mine while they got in doing the Cam Install.
Dan
MeanV8 is offline   Reply With Quote
Old 07-09-2020, 06:04 PM   #5
InFiD3ViL
InFiD3ViL's Avatar
Dan
Nice! 3.91s?
Man, I want a set of gears so bad. But I need a convertor too, for sure. My car pushes bigtime at stop lights. I'm hoping to do both at the same time.
Old 07-09-2020, 08:14 PM   #6
samman11
$1550 total. That INCLUDES the recalibration of the speedometer. Best price I got after an extensive search. Plus, I'll get back the 3.45 gears, and I suppose I can sell them for $150 or so. Only 19,000 miles on my camaro.
Old 07-09-2020, 08:26 PM   #7
InFiD3ViL
InFiD3ViL's Avatar
Man, that's steep. Is that including the gears or in addition to?
As long as they do great work, you have the bucks to spend and are happy in the end - that's all that matters.
Old 07-09-2020, 08:56 PM   #8
Splat
Splat's Avatar
Drives: 2012 1SS M6 IOM
That's roughly what I spent, and that was including the 3.91 gears.
Only thing i wish i added was the Z/28 LSD and cooling package.
All I can say is, when my dealership completed my gear swap, my car ran 10 times better.
2012 1SS Camaro LS3 Inferno Orange
Mods: LSA Supercharger, 2.55 Pulley, Custom Boost Cam, ARH LTH 1 7/8, HFC, 3' Magnaflow Exhaust, JLT CAI, Elite CC V2, BO White Stage 2 TB, GM 3.91 Gears, DSS CF Driveshaft, BMR Bushing Kit.... . Tuned by JTM Motorsports 540 Hp 550Tq on 9PSI
Axles, Monster Clutch, Hotchkis TVS Track Pack kit.......For 2018.
Splat is offline   Reply With Quote
Old 07-09-2020, 09:15 PM   #9
BehindBlueI's
What should it run?
BehindBlueI's is offline   Reply With Quote
Old 07-09-2020, 09:39 PM   #10
InFiD3ViL
InFiD3ViL's Avatar
Originally Posted by BehindBlueI's View Post
What should it run?
Well there really is no 'should' amount. That's just steep for me. I also don't know if that included his gears or not - but I assume it does.
Gears themselves usually cost between $300-550, depending on the completeness of the kit. I have seen multiple people pay $500-700 for labor and also plenty of people paying closer to this price, but usually that includes the gears. I would say the average I have seen is around $1200, gears & labor. But it tends to vary greatly depending on your region.
So $1550 total including the gears isn't all that bad, especially knowing it was dealer installed. It is just on the higher end.
Keep in mind a lot of people will remove the diff themselves and bring that into the shop for the gear swap, saving a lot of money on labor. Then they can have their tuner adjust the tune for the new ratio.
Old 07-09-2020, 09:50 PM   #11
Vegas Bound
Drives: 2013 Sparkly Red One
I had 3.73 LSD gears added to a Silverado at the dealership and it cost me $900.
Vegas Bound is offline   Reply With Quote
Old 07-09-2020, 10:52 PM   #12
Silveradoss573
Drives: Camaro 1LE
My 2011 Silverado rear locker came apart a couple of years ago out of nowhere. Yeah I admit that i paided the dealership more than other shops in the area, but they also gave me a 3 year unlimited milage warranty. Only thing they asked was that after a few hundred miles that I came in so they could pull the cover to check the fluid and components.
Silveradoss573 is offline   Reply With Quote
Old 07-10-2020, 01:55 AM   #13
samman11
Yes, that's total WITH gears. I had one shop quote me that price WITHOUT speedometer recalibration, which you can buy device on your own to do. The problem is that those tune devices can run around $300. Other speed shops were anywhere from $2000 to $3000. One guy initially stated "under a $1000" until he found out that it was a 2011. He screamed extensive labor due to the fact that its independent rear suspension. Based on what I see, he is correct in his labor concerns. Sure, there are guys who claim that this can be done in your driveway with the car on a jack. I say "Good luck." The way I see it, I've got a GM tech who knows what he's doing. He's done five of these before. That's worth the money to get it done right.
Old 07-10-2020, 03:27 AM   #14
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Wow that is steep I got my gears from Maureen it’s was a GM kit 350’ish and 750 for the dealer to replace also installed my 1LE shafts as well.
Orange Krush II
