06-10-2015, 11:30 AM | #1 |
Drives: 2010 2SS/RS Camaro Join Date: Aug 2014
H-E Offset Differential Bushing Install Photo's
Ok guys, I finished up installing the new Ride Tech Level 2 Coil Over suspension on the 2010 SS a short while back, & after lowering it TWO full inches the angles of the axle shafts were down right scary!
The good news is that Thomas Hendrix from Hendrix-Engineering saw a thread I posted regarding the excessive axle shaft angles &called to let me know that he had just released a NEW product that would RAISE the REAR differential up to help correct for the now excessive axle shaft angles from lowering the car past 1.5 in. The soft rubber OEM Factory Diff. bushings are replaced with Delrin & the bolt holes are offset approx. .625 or 5/8 of an inch from the center of the factory bushings. This offset hole location makes a HUGE difference in the AXLE SHAFT ANGLES & allows the Camaro owner to lower the Camaro a full TWO inches if desired & GREATLY lessens the chance of axle shaft failures. The Delrin bushings also almost completely eliminated the wheel hop that I was getting as well. The offset Delrin bushings that I purchased from Hendrix- Engineering has been the BEST & SMARTEST $150.00 I have spent on the Camaro thus far. Also Thomas is a straight up, what you see is what you get kind of guy! If you call him & have to leave a message, YOU WILL get a call back in a VERY short time! Attached are a few photo's of the install. Yes I did ALL the work myself. Feel free to PM me if you have any questions. All The Best, Orange 2010 Camaro |
06-10-2015, 12:31 PM | #2 |
Drives: 1969 SS/RS Camaro Join Date: Nov 2013
So these are the bushings you were telling me about yesterday.... Car looks awesome!
06-10-2015, 12:47 PM | #3 | |
Drives: 2013 Camaro 1LE Join Date: Jul 2012
06-10-2015, 02:31 PM | #4 | |
Drives: 2010 2SS/RS Join Date: Dec 2009
Bushings
06-10-2015, 04:02 PM | #5 |
Drives: 2010 Camaro SS/RS CGM Join Date: Dec 2011
Hows vibration and noise from these bushings? I just did a engine mount replacement with pfadt look alikes and its kinda howly already at certain rpms so i would not want much more vibration.
06-10-2015, 09:13 PM | #6 | |
06-10-2015, 09:24 PM | #7 | |
06-10-2015, 09:49 PM | #8 | |
Installing the H-E offset bushings, IN SIMPLE TERMS, RAISES the differential UP in the rear cradle TO SIGNIFICANTLY REDUCE the EXCESSIVE AXLE SHAFT angles that you get from lowering the Camaro more than 1.5 inches. Take a close look at the photo's of my Camaro as well as the additional photo's of the install & you can get a good idea as to why spending the $150.00 on them is the best money you will EVER spend! All The Best, Orange 2010 Camaro Last edited by Orange 2010 Camaro; 06-10-2015 at 09:53 PM. Reason: add word |
06-10-2015, 10:09 PM | #9 | |
Thanks for the explanation!
06-11-2015, 07:37 AM | #10 |
Drives: 2010 2SS-RS, IOM, M6 Join Date: Mar 2012
I got mine in yesterday, as Orange 2010 stated installation easy, PIA removing factory bushings so have some tools. CV angle 100% better I am lowered as well with Eibachs. Still have other things I am doing so car not ready to drive yet.
2SS/RS, Inferno Orange, 6sp, Eibach lowering springs, Eibach adjustable sway bar, Exhaust 2.5" dumps before axle, New ERA OTR intake, TSP LS3 225/230 .617/.612 on a 112LSA cam,
Rocker arm trunion kit, ported/polished heads, JRE Tune, ARH Headers, G-Force Axles, 3.91 Gears, Eaton Detroit Truetrac /w Billet Caps, MGW Shifter, DynoTech Driveshaft, E2X Catch Can . |
06-11-2015, 09:13 AM | #11 |
SS
my offsets arrived yesterday ride tech stage 2 and a spohn anti wheel hop kit Tyler at JDP put together for me are getting brought to Sturgis can"t wait , Your setup looks great Orange! how does the stock Guibo joint angle look? I was thinking a one piece drive shaft upgrade might be in the books
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
06-11-2015, 09:39 AM | #12 |
SS
drive shaft shop gets rid of guibo rubber joint and runs the a u joint , now what do I want aluminum or graphite hmm?
06-11-2015, 10:09 AM | #13 | |
I sleep much better now , if you know what I mean! It is just ONE LESS thing to worry about. As for installing the Delrin bushings, drill out the soft OEM bubber bushings using a 2in. diameter hole saw first, & then use a saws-all with a FINE TOOTH , BI-METAL BLADE to cut through the remaining rubber OEM bushing in a couple of places, as well as the STEEL SLEEVE that you will have to knock out using a flat blade punch. CAUTION- CAUTION-CAUTION------- WHEN YOU ARE USING THE SAWS-ALL TO CUT THROUGH THE REMAINING SOFT RUBBER & THE METAL SLEEVE , BE EXTREMELY CAREFUL THAT YOU DO-NOT CUT INTO THE DIFFERENTIAL CASTING !!!!!! What I did was after cutting through the remaining rubber left from the hole saw, I ONLY ran the saws-all for TWO OR THREE SECONDS AT A TIME until I had cut through the steel sleeve, Also you can do the entire job with the differential & axle shafts in the car. Make sure that you put some type of padding under the inner CV joint boots to protect them before you lower the differential. I hope this install info. helps you. All The Best, Orange 2010 Camaro |
06-11-2015, 11:29 PM | #14 |
SS
thanks those pics help visualize the job , do you think a good shop press will get them out? I want a graphite shaft its on the list anyhow ,but that's good if the stock shaft fit well!
