02-06-2012, 04:36 PM | #1 |
Space Coast Camaros
Drives: 2012 Camaro Vert Join Date: Sep 2011
OEM Radio Power source
OEM Radio Power source.
Anyone know where i can tap in to give the Stock Radio power? At shows I don't want to leave the keys in and its killing me to reset everything every ten Min's. I know the main computer is controlling the power and turns it off after time. But I should be able to tap in with a fused 12v switch source and leave it on when i want. or is there a way to change the timeout?
02-06-2012, 09:33 PM | #2 |
Drives: 2010 Camaro Join Date: Feb 2011
there is not good way to do this with a factory radio, it is part of the GM Can system, and the cars BCM tells the radio to turn on when the key is on via data. Same goes for the key, it does not actually turn on any ign source any more what it does is the BCM registers the key code and when you turn the key it changed different resistances to let the cars BCM know what is going on. the best you could do is either leave the key on or turn the key on and off with having the door switches pushed in and it will leave the radio on for 10 mins.
I ran into this same problem so what I did is ran 2 batteries one for the audio and one for the car so I wont kill the cars starting if Im at a show then I used a signal selector for Ipod so when the car is off I can turn on the amps and play the sound through my Ipod into the amps with out the radio on.
2010 JL Audio
Build Thread: http://www.camaro5.com/forums/showthread.php?t=139419 #280 MASTER MECP Certified MECP - Sales, Basic and Advance Certified ASE - 6 electrical certified 10+ years car audio installation, sales and manager |
02-07-2012, 01:45 PM | #3 |
Space Coast Camaros
Thanks for 101.
So the radio always has 12v and then get s signal to turn on or off? that sucks. Also got any information on the Dual Batteries and how you did it? I like to see that since i have to do the same thing.
Thread Tools | |
Similar Threads | ||||
What do all the abbreviations mean? | CrzyGamr2 | 5th Gen Camaro SS LS LT General Discussions | 77 | 12-07-2012 04:34 AM |
Modifying for " Dummies" | Dr Jkel | Tuning / Diagnostics -- engine and transmission | 209 | 06-17-2012 11:24 PM |
No power to dome light, airbag, horn, and onstar after installing radio...HELP!!! | meltyface | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 8 | 05-15-2011 07:41 PM |
Camaro info from GM | dahulk | 5th Gen Camaro SS LS LT General Discussions | 5 | 03-01-2011 10:39 AM |
ABL Power source ??? | cdn2usa | Cosmetics and Lighting Modification Discussions | 14 | 02-22-2011 10:19 PM |
