Old 10-03-2016, 06:56 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Question Stumped from what I was told. Not Camaro related
Ok so would like to see what some others think of what I was told the other night.
Had a friend get an engine built. It's a 4 cylinder. This person is wanting to make around 500whp.
Well his engine builder told him he didn't have to balance his rotating assembly even tho the original crank was used and the rods and pistons was bought separately.
I'm sure you don't absolutely need to balance them but making that power on a 4 cylinder And dumping that money into it. Why woundnt you?
The thing that I found concerning was the fact that when he switched to main studs his builder said you don't need to line hone the main caps all you need to do is run over sized main bearings. ( The crank was not turned only polished)
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 10-03-2016, 07:03 PM   #2
redcoats1976
to make 500 hp.with a 4 cylinder its going to turn a lot of RPM.it sounds to me that his engine isnt going to make 500 hp.for very long...
Old 10-03-2016, 07:25 PM   #3
MrChrisLS3
Drives: 2018 1SS M6
I would suggest your friend find another engine builder. This one is either not very bright, or very lazy. Failing that, suggest that when the car goes on the dyno, if he's in the room, to wear full body armor.
MrChrisLS3 is offline   Reply With Quote
Old 10-03-2016, 08:40 PM   #4
2010_camaro
All I could do was laugh. I tried to tell him his engine builder fuc#ed him but he just gets mad and says nothing is wrong with it.
It has a twin disk in it and im like 100% sure the throw out bearing is junk or put in backwards if that's even possible.
It sounds like two skeleton's fuc#ing on a tin roof when he pushes the clutch in.
But his builder says everything is normal.
Old 10-03-2016, 08:49 PM   #5
MrChrisLS3
Drives: 2018 1SS M6
"Skeleton's on a tin roof" Lol
Go ahead and call the tow truck, tell them the car is sitting at the intersection of Time and Truth.
Old 10-03-2016, 09:08 PM   #6
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Why bother building a 4 banger?
One of my nephews loves blowing those things up. He buys another used one, ups the boost and has a blast.
When I was over there last he had a few blown motors sitting in the back yard. I asked him about that and he says, "They're cheap and I have fun!"
Can't deny that logic.
Oh, and he drives a tow truck for a living
CamaroFred is offline   Reply With Quote
Old 10-04-2016, 10:14 AM   #7
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
One of the guys I track with has a built up subaru making the same HP as our LS3 and let me tell you that thing is insane on the track. Smaller and lighter than my 1LE and same HP with AWD. It's a fast, fast track car. Lap after lap.
Thor142 is offline   Reply With Quote
Old 10-04-2016, 10:23 AM   #8
drew peacock
Banned
Drives: 2012 2SS INFERNO ORANGE
check that out
over 1000 bhp road car
2l 4 pot motor..not many camaros would ever beat that
drew peacock is offline   Reply With Quote
Old 10-04-2016, 11:27 AM   #9
Orange skid mark
Just an average Dude
Drives: 2015 1LT Grey w/Orange Rally Stripe
You gotta love the grenade motor mentality. As long as you have money to burn.
So far I like my car the way it came from the factory.
Orange skid mark is offline   Reply With Quote
Old 10-04-2016, 11:58 AM   #10
MrChrisLS3
Drives: 2018 1SS M6
I have seen a more than a couple of 4 bangers run under 10 seconds in 1/4 mile. These can certainly be built to make great power reliably. However, the same rule applies...
1.Cheap
2.Fast
3.Reliable
Pick any two.
Old 10-04-2016, 12:34 PM   #11
BMR Sales
BMR Sales's Avatar
Drives: Race Car
I agree! a Four Cylinder needs to be balanced for good horsepower as most want to shake themselves apart, especially in a big 4 cylinder. That is one of the reasons why Porsche put in Counter-Rotating Balance Shafts in 944 Motors
Old 10-04-2016, 12:46 PM   #12
RvdB
RvdB's Avatar
Drives: 2010 Camaro 2 LT RS package
Strong rumours about Mercedes/AMG are developing a streetlegal hypercar: 1.6 ltr V6 turbo 1000 hp (formula 1 based) "supported" by 2 electrical powerunits wich delivered 300 hp, so 1300 hp under the hood......
If i ever win a (big) lottery
RvdB is offline   Reply With Quote
Old 10-04-2016, 12:48 PM   #13
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
A big yes to both align bore and balancing.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
