Old 03-19-2013, 06:33 PM   #1
Rocks RS
Rocks RS's Avatar
Drives: 2010 Camaro 2LT/RS
Do I need a tune?
I have a 2010 with 119,500 miles on it. I have a injen longtube CAI, and MRT V1 exhaust. The exhaust has been on for years, the intake is recent.
In December, GM/ dealership replaced my timing chain because I kept getting P2097 codes and they said it needed replaced. I had not had a problem until last Friday. I got the code again. It went away about 3 days later. After about 2 more days, it has come back on again.
Do I need a tune because of the injen CAI or does it need to go back to shop.
Also, I have changed the plugs just in case that was an issue.
2010 Camaro 2LT / RS - Black w/IO interior & M6
Sporting MRT V1, Hurst short throw, and Injen long tube and loving it!!!
Also, over 125,000 miles and going.
Rocks RS is offline   Reply With Quote
Old 03-19-2013, 06:54 PM   #2
Decepticon21
Decepticon21's Avatar
Drives: 2010 Camaro v6
If its the same code then you should take it back to the dealer. AND figure out why that code keeps coming back since you have had the work done to fix it.
Decepticon21 is offline   Reply With Quote
Old 03-19-2013, 06:57 PM   #3
melvinakshay
Vrooom Vrooom
Drives: Camaro 2011 black LS
No you need a new car
Performance Mods :- MRT V2.0, Vararam CAI, Trifecta Tune.
Appearance Mods :- Angel Eyes, Havoc Rims
Sound Mods :- *to be updated* -special thanks to darkrider01
melvinakshay is offline   Reply With Quote
Old 03-19-2013, 07:02 PM   #4
10RsCamaro
Slow v6
10RsCamaro's Avatar
Drives: Automatic Automobile
Send a message via Skype™ to 10RsCamaro
Whoa that is a lot of miles!!! Good luck man! Smells like a lemon!
Full bolt on 2lt/Rs. Any questions? always a pm away!
Obx/Mace/Rx/Mrt/Vararam/Bcam/4.11 Gears/SS Brakes
USAF. Stationed in TX
10RsCamaro is offline   Reply With Quote
Old 03-19-2013, 07:06 PM   #5
spyder
Drives: 2010 V6 | M6
I have a 2010 as DD and I'm roughly at 49k which makes me feel that I drove it a lot. You're almost at 120k! Wow!
A tune will probably help you clear the CEL, you should scan the car and make sure it's the same code. If it is then go back to your dealer for further diagnostics.
BBK 304 LT headers w/ coating | CAI Inc Intake w/ scoop | VMax Ice-olator | MRT v2 | Elite catch can | Trifecta Tune | Eagle halos | 20" Textured Black Forgestar F14s
- They call it the black panther.
2010 Camaro LLT (sold)
2008 Yamaha WR250X
2011 Nissan Armada 4WD Platinum
spyder is offline   Reply With Quote
Old 03-19-2013, 07:07 PM   #6
Rocks RS
Rocks RS's Avatar
Thanks for all the info folks.
Old 03-19-2013, 07:15 PM   #7
rsflyer
rsflyer's Avatar
Drives: 2010 VR 2LT/RS A6
Question A few...
...questions...
Did GM replace the timing chain on their dime?
What was the car's mileage when they did the job?
Was the replacement related to a TSB?
Don't know whether you need a tune or not, but getting it could help you rule it out as an issue.
BTW, I think it is great that you are still driving the car. Shows courage & conviction.
Its not how fast you go, but how you go.
rsflyer is offline   Reply With Quote
Old 03-19-2013, 07:16 PM   #8
KMPrenger
KMPrenger's Avatar
What I'm curious is, how many miles were on the car when they replaced the chains? Seems to me you may have been outside of the regular warranty, but they replaced them anyways....which seems to be the common thing. Even modded cars are getting chains replaced under warranty....so this is a good thing.
As for the code, take it back for sure.
With that many miles on your car, and if you haven't been running a catch can I'm betting that girl could use some sort of upper induction cleaning. The valves are probably all gunked up, which is hurting your performance.
Old 03-19-2013, 07:16 PM   #9
KMPrenger
KMPrenger's Avatar
Originally Posted by rsflyer View Post
...questions...
Well you beat me to it lol
Old 03-19-2013, 07:20 PM   #10
rsflyer
rsflyer's Avatar
Arrow ...
Only by a minute or less...
Old 03-19-2013, 07:33 PM   #11
Macrackie
Macrackie's Avatar
Drives: 2011 Camaro LS Stripper model
Wow good job putting the miles on that thing...you racing to be the first to 200,000?
I have many of the same already asked questions so I'll just wait for the answers.
Macrackie is offline   Reply With Quote
