09-12-2014, 08:55 PM | #1 |
9.56@144.09
Drives: 2013 zl1 black Join Date: Mar 2013
417 vs 427
I have a zl1 Camaro with a lsa motor and want to know if there is much HP difference between a stroked 417 and a 427.
09-12-2014, 09:15 PM | #2 |
Drives: '11 Camaro Supercharged Convertible Join Date: May 2014
One of the reasons that you see 416-418 is because the stock aluminum block is still used allowing it to be pushed more. When you go to a 427 on a STOCK aluminum block, the cylinder walls become too thin for high boost. If you go with a 427, either use a LSX block which is aluminum, or get a properly built aluminum block that has been resleeved. Both block that you mentioned can easily make big power, but unless it's built and tuned right, it may not last. I chose to do a 427 because to me it just sounds better and rolls off the tongue more easily. Knowing about a GM LS7, and the power goal I had in mind, I chose to use the LSX block.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
09-12-2014, 09:37 PM | #3 |
9.56@144.09
I know you can not take a lsa block to a 427 I would use a ls7 block. what I want to know is there much power difference between the 417 and the 427.
09-12-2014, 09:47 PM | #4 |
Simply put no. It comes down to the power adders. Both can hold the same power and you can make the 6.2 into a 427. They are bored out to that size regardless if it's a LS3 or LSA.
09-12-2014, 10:29 PM | #5 |
You wouldn't want to really boost a ls7 block either.
Power difference would be minimal at best. Not worth it.
Nick
Corvette Z06 -1200ish rwhp |
09-12-2014, 10:40 PM | #6 |
Drives: 2011 ss camaro Join Date: Jan 2013
I think the lsx block is cast iron and weighs about 100lbs more than an aluminum block.
09-12-2014, 11:06 PM | #7 |
That is correct. As strong as it can be it traps in a lot more heat.
09-13-2014, 03:52 PM | #8 |
Drives: 2012 CTS-V, 2010 Camaro SS Join Date: Sep 2013
434 LSX baby.
2012 CTS-V: Cosmetic Chute. |
09-15-2014, 09:50 AM | #9 | |
Drives: 06 Z06 TT Join Date: Nov 2013
^^ over kill in a boost car... their is a reason some of the big players have even dropped below a 427... its not needed. only thing a 427+ is good for is spooling up a T4 twin turbo setup. beyond that any size motor with the right setup will still make the same power. id take a 4.125 bore with a stock 3.622 stroke..... and let the turbos do the work. |
09-15-2014, 11:18 AM | #10 |
Agreed, if he had turbos. I guess it depends on the power adder. If you are running a stock zl1 blower, I would stay stock cubes.
Big bore short stroke is an awesome combo.
Nick
09-15-2014, 11:52 AM | #11 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
Yes, he has two badass Comp oiless turbos and spray on top of that. Should easily be over 1400whp when all is said and done.
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
09-15-2014, 09:54 PM | #12 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
There is no replacement for displacement. It gives you more torque and more room for air and fuel. You can make more power with more displacement.
In reality you have to get pretty bat guano crazy with forced induction to be able to take advantage of all of those cubic inches. Unless you are talking the 4 liter Kenne Bell and Whipple blowers, you can run all of the top mount blowers flat out at max rpm on a 376 and get pretty close to the same air into a 376 as 434. Now if you go with the really big centry's or big turbos you can make more power with more displacement. Turbos like more displacement, it helps them spool faster and you have more power before they come into boost. If you are talking specifically about the stock ZL1 motor I would not bore it to 427. 417 is as big as you should go on the stock block. If you are starting with a new, ERL, RHS, LSX... I would go 427.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
09-16-2014, 10:38 AM | #13 | |
then the big motor is really just a waste.. |
09-16-2014, 11:14 AM | #14 |
Well my 434 just made 903whp at 10.5psi lol. I'd say <3 434s.
