05-28-2015, 01:05 AM | #1 |
GT500 Heat exchanger on a SS/ZL1
I started my LSA supercharger install on my 2012 Camaro SS. I purchased the kit form ADM, link below. After I did some research on the net on various forums, including this one, I found that the stock heat exchanger is simply not enough. This build was supposed to be a low cost build so I didn't want to purchase a $1k heat exchanger. On another forum, something caught my eye. Someone mentioned that people have installed the heat exchanger off of a 2012+ GT500. I thought this was crazy and interesting, but I could not find any other information on the net concerning this. So I decided to jump on it myself and try it out.
I purchased a used heat exchanger from eBay from eBay for $200. It's a dual pass and is thicker than the stock ZL1 heat exchanger. The outlet and inlet ports don't match up and brackets would have to be made but this is can work. I'll keep this post up with pictures of my install. I'm not going to add too much stuff from the LSA supercharger install cause there is a really good one here already. ADM Performance LSA supercharger install kit: http://lsa-conversion-store.myshopify.com/ LSA Supercharger Install: http://www.camaro5.com/forums/showth...=385577&page=6 |
05-28-2015, 02:15 AM | #2 |
Drives: 2010 SS L99 IOM Join Date: Aug 2012
Pretty cool- really interesting.
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins |
05-28-2015, 05:06 AM | #3 |
C'mon- really?
Drives: Looking for a ZL1 Join Date: Aug 2009
Steve
2018 Camaro 2SS 1LE Black #3805 - SOLD |
05-28-2015, 09:20 AM | #4 | |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
05-28-2015, 11:47 AM | #5 |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
just to illustrate the stock HE size. Here is stock versus the LPE one I just put in
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
05-28-2015, 12:21 PM | #6 |
They have two kits, one with and one without the supercharger. You can buy a used take off supercharger from eBay for anywhere between $400 to $650. This is what I did. All I had to do is pull the snout and replace the coupled with the solid version.
05-28-2015, 12:37 PM | #7 |
05-28-2015, 12:47 PM | #8 |
Here is a pick of the heat exchanger from a 2012+ GT500. Note that there are a few brackets that need to be cut off. Also, the outlet port on the top would need to be cut down or moved. I cut mine down to clear the front grill.
05-28-2015, 01:03 PM | #9 |
The stock ZL1 hoses might be a good starting point for you. Other than the left side having a built in 90º, they are in the same relative location.
05-28-2015, 01:04 PM | #10 |
ok. Here is a picture of the heat exchanger installed without the front bumper cover. As you can see, it takes up a lot of space. I had thought about running fans but with a 4.5" width, there was no way I was going to be able to fit fans on it. I had plan to running my lines on the driver side so I had no issues with the way it's routed. This may pose as a problem for a ZL1 but if you had the outlet neck rotated down, i'm sure this could be managed. I did have to remove the trim of the air trey (if thats what is called). Which means I had to relocate the ambient air temp sensor. There is good enough room between the AC condenser and the heat exchanger and the front bumper. The GT500 brackets almost made it to the stock holes on the radiator frame support. It was off by at least 1.5". There was enough length to avoid making a bracket. I did, however, needed to make long spacers for the bolts that attached to the heat exchanger to the radiator support frame. This can be seen on one of the attached images.
07-17-2015, 04:58 PM | #11 |
****Update****
I've been driving around in the car with the LSA blower for a month already, pushing 9lbs of boost. Since I installed the heat exchanger, I added a 11" radiator fan mounter between the HE and the bumper guard. I did have to shift the HE back 1/2 inch, but every fits fine. Also, running 100% filtered water with Redline waterwetter Results: Ambient temps vs IAT Ambient Temp: 75F 70mph cruising: 79F Stop and go traffic 40MPH: 85F 3min idle after driving: ~85F from 90F WOT 1/8 mile run: 110F from 85F Time to drop 25 degrees from 110F: 5min @ idle Last edited by Jamob; 07-17-2015 at 05:51 PM. |
07-17-2015, 11:13 PM | #12 |
'It's an experiment'
Very nice! I like the mod... Super job on working down those temps...
-Don
747 RWHP 794 RWTQ
07-18-2015, 12:11 AM | #13 |
KaBoom1701
Interesting...
How much was the total cost of all this?
Mods:
07-20-2015, 02:08 PM | #14 |
Drives: 2014 Subaru Forester Turbo Join Date: Aug 2013
Nice work
Thread Tools | |
