11-17-2011, 05:12 PM | #1 |
Drives: 2010 Camaro 1SS/RS LS3 blck w/ IOM Join Date: May 2010
Grease for bushings?
Okay so I understand bmr sells super lube that's silicone based. But I just wanna go to the store and get it, I don't want to wait a week to recieve it. What other greases are you guys pumping into your suspension bushings and what else can I use if I don't find a silicone grease that's synthetic. I'm very close to just buying water resisten multi purpose or lithium grease.G
TSP 229/236 cam .Magnaflow Comp axleback .KOOKS LT w/ high flow cats .magnapack bullets. C.A.I. Vmax ported TB. Dyno tuned 452hp / 422tq.
11-17-2011, 05:16 PM | #2 |
Drives: 5th Gen Rental Join Date: Aug 2007
Pedders bushings come with lubricant and once installed do not need to be re-lubricated.
What brand of bushings are you looking for grease for? |
11-17-2011, 05:22 PM | #3 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
We have had great success with Energy Suspension Formula #5 on poly components for Corvette and Camaro. You may be able to pick it up locally if you can find an Energy Suspension dealer in your area. The stuff is high quality marine grade grease and works great. It's super tacky and water resistant and is really the bees knees as far as poly bushing lubrication goes.
11-17-2011, 09:25 PM | #4 |
Drives: 2010 SS2 Camaro Join Date: Jun 2010
I have used the Energy Lubrication grease on a large number of sway bars. I have not been happy with it. This grease dries out pretty fast and has been a major issue with squeeks.
11-17-2011, 10:22 PM | #5 |
They're for bmr's trailing arms, I just need to get grease into the nipple things for the polyurethane bushings
11-18-2011, 09:13 AM | #6 |
Drives: Race Car Join Date: Sep 2009
If you use the incorrect grease (multi-purpose or Lithium) it can breakdown the bushing and soften it up, using the correct grease is key to maintaining a happy and healthy bushing. Another option beside the Super Lube that I have personally used and many BMR customers have use is the Mobil 1 synthetic grease.
11-18-2011, 09:26 AM | #7 |
As mentioned by BMR, the Super-Lube Synthetic works great, I've used it with all my bushings with no squeaks or creaks at all. I found a cartridge like this at Ace Hardware for I think it was $8.99 or so.
11-18-2011, 10:00 AM | #8 |
Okay thanks, I called another hardware store nearby and they carry super lube. It says syncolon and not silicone but probly the same thing
11-19-2011, 09:39 AM | #9 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Syncolon, whattha?
Had to look it up! Syncolon PTFE- its teflon. Properties look entirely applicable to our needs. Go for it! |
11-21-2011, 09:01 AM | #10 |
That's the stuff, go pick some up and get the bushings greased and you should be good to go.
Similar Threads | ||||
grease points | Cyber/Orange10 | Camaro DIY & HOW-TO instructions & discussions | 13 | 03-30-2012 06:48 AM |
Lithium grease. | alssiri | Suspension / Brakes / Chassis | 18 | 07-14-2011 04:39 PM |
GREASE ON INSIDE REAR WHEEL!!!! | Peter W. | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 6 | 03-29-2011 07:08 AM |
BMR Trailing Arms Grease | oachalon | Suspension / Brakes / Chassis | 19 | 12-28-2010 01:20 PM |
Grease and tar, etc | Tee304 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 9 | 04-28-2010 12:55 PM |
