05-21-2010, 10:30 PM | #1 |
Drives: 2000 camaro Z28 & 2010 SS w/ RS Join Date: Apr 2010
i need some advise...on a 4th gen... i know i know,,,
so my 4th gen 2000 is a V6 automatic... laugh if you want i don't care...
and i keep checking the antifreeze and it's brown and gunky... i go in and get it flushed and guess what a week later... the same thing happens...and now it over heats. ugh! has anyone had this happen before? idk if oil is leaking in somehow... or what the deal is... there's no crack in the radiator no fluids on the ground... and it doesn't over heat if the car is just sitting there running it's only when it's been on the road a few miles... literally with in 5 miles it will over heat... i'm terrified to move it incase something blows or cracks... help me fix my baby!
Cristykay07
[SIGPIC][/SIGPIC] loves 4th and 5th gens. |
05-21-2010, 10:39 PM | #2 |
Drives: 2010 Challenger R/T;2011 Mustang GT Join Date: Jan 2010
Check your oil. If it is milky you have a head gasket issue most likely. If the oil is good, I would recommend a thermostat and water pump change. That should get you back in business.
05-21-2010, 10:42 PM | #3 |
Thank you Thank you Thank you. I thought the water pump too so i have that i'm just waiting for the hubby to come back from training in Cali to fix it for me. and can i just bring the car to the dealership for the thermostat change?
Cristykay07
05-21-2010, 10:47 PM | #4 |
and what do you think about the hoses... could they be collapsed?
Cristykay07
05-21-2010, 11:13 PM | #5 |
Always a good idea to check the hoses. I would think the dealer could do everything from the t-stat to the water pump and inspect the hoses.
05-21-2010, 11:53 PM | #6 |
www.Camaro5store.com
I remember this same question a while back and it was the same leak like wbt said. I think it was the oil that was leaking into the antifreeze.
05-21-2010, 11:59 PM | #7 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
Yep, you got oil leaking in.
05-22-2010, 02:08 AM | #8 |
@MrRaZ28
That is definitely a blown head gasket. Had the same issue with my Eclipse (and honestly, still do... not willing to shell out $3000 to fix a car not even valued at $1000 by a dealer). Had what mechanics call "ice cream" as well.
Essentially, it's not good. I don't know how hard it is to replace a head gasket on a chevy v6, but I know with Mitsubishi, you have to take EVERYTHING off and out of the block to change the head gaskets. Good luck! |
05-22-2010, 02:21 AM | #9 |
Drives: ls3 ss Join Date: Jan 2007
it sure is oil leaking into water , you should first check your engine oil level and condition ... is it going low or changing color ... next thing that i can think of is, as your car is an automatic it could be transmission oil cooler leaking into radiator if it's equiped with one
05-22-2010, 06:46 AM | #10 |
Back on the dino-juice
Drives: '10 LS + a few more Join Date: May 2010
There's a lot of chemicals at Autozone, Oreilly's, Advanced. There is one in particular that is "guaranteed" to fix blown head gaskets. I can't remember which one it was, but I remember it was talked about on the Two Guy's Garage TV show. I think it's around $10 or $15. I know you work at the dealership but it might be worth it to go that route first.
Years ago my uncle taught shop class at a community college and as we were putting my '73 Firebird's 400 back together he told me he would've tried the cheap fix first. I asked him what he meant and he said the chemical fix. |
05-22-2010, 09:13 AM | #11 |
alright... i have the antifreeze and a water pump...i'm pretty sure it's also oil leaking in... gotta check the hoses... yay...ugh.
and does anyone know of a flush chemical they might sell that the autoparts store for the radiator? looks like i got alot of work ahead of me. ugh.
Cristykay07
05-23-2010, 12:46 AM | #12 |
You want my advise? Trade it in for a BRAND NEW one!!! |
05-23-2010, 02:33 AM | #13 |
Reality Check Specialist
I'm a little confused: you say your 2000 is a V6, but in your sig and under what you drive, you list a "2000 Camaro Z28"... I know you know the difference, but I have to ask what you really drive, because diagnosis and repair of items is completely different for the LS1 vs. the 3800 V6
05-23-2010, 10:21 PM | #14 |
let me explain the badging has been on since i was in high school from the previous owner and yes it is a v6 automatic... im assuming the z28 in those days were v8s idk.
either way my v6 has smoked plenty of mustang gts in its day.
Cristykay07
Similar Threads | ||||
Does anyone have a 4th Gen that has better performance then a 5th 2SS? | GTAHVIT | 4th Generation Camaros | 92 | 10-09-2009 08:32 AM |
5th gen 4th gen chevy firebird???????? | SicSix6 | Camaro Photoshops / Renderings Forum | 2 | 08-10-2009 06:52 PM |
4th gen help... :( | Navy Blue | 4th Generation Camaros | 15 | 08-07-2009 12:43 PM |
4th Gen Miles Question | dobbins67326 | 4th Generation Camaros | 13 | 09-05-2008 10:37 AM |
Condensation in late 4th gen headlights? | MAC | 4th Generation Camaros | 27 | 06-30-2008 01:53 PM |
