08-22-2016, 03:48 PM | #1 |
Trouble with shifter install
Currently in the process of installing hurst short throw shifter and I am not able to remove the cross pin from factory shift lever. Has anyone else had this issue? Or know a solution???
I've been trying for to remove this for about half an hour. Even tried prying it with a screw driver. It is not moving at all. Sent from my iPhone using Tapatalk |
08-22-2016, 05:47 PM | #2 |
Am I the only person who's ever had this problem?? All the videos and step by steps I have viewed, the pin just slides right out....
08-25-2016, 09:19 PM | #3 | |
Drives: 2013 ZL1 VERT M6 Join Date: May 2013
VIDEO
Make sure both pins on both sides are out. The below video is from hurst. They say you can tap the pin on the end to help start it, but do not maul it as you will have to reuse it. Good luck and let us know. http://www.bing.com/videos/search?q=...=0&FORM=VDFSRV
JANNETTY RACING 750 ROUGH IDLE CAM PACKAGE
(681 RWHP & 643 RWTQ) = 783 CRANK HP & 740 CRANK TQ |
08-25-2016, 09:23 PM | #4 |
Thanks. I had used that video and tried moving the shifter in all kinds of directions. I eventually resulted to tapping it out with a pry bar. Did not damage anything. Rest of install went smoothly.
