03-13-2013, 01:18 PM | #1 |
ZL1 owners that have aeroforce gauge need help
Hi! I just bought the aeroforce gauges and have a question for those that have these gauges that own a ZL1.... Does our car support the A/F ratio reading? OR do we need to buy the wideband sensor to make it work? If we DO need the sensor kit has anyone installed the kit??! Thank you for any information!!!!
Sit Back and Enjoy The Ride!!
03-13-2013, 03:18 PM | #2 |
I think I found my answer..... Anyone install the kit to read the A/F Ratio???
03-13-2013, 04:09 PM | #3 |
Mid-Florida Camaro Club
Drives: 2019 ZL1 on Order Join Date: Jan 2011
Not installed the kit but would like to - not sure how easy/difficult it would be to do so if anyone has it done then would love to know.
(and I guess you worked it out but No it doesn't work without the Wideband sensor)
03-13-2013, 04:16 PM | #4 |
Unfortunately no... Need the kit.... Kind of misleading cause I know our ECM IS wideband... Still would of cost 600 though to get the auto meter gauges I wanted... Boost and A/F Ratio... So it's the same cost as those two gauges... but we still have a lot of other parameters to view at the touch of a button...so IMO still worth the money.... I read the directions... Doesn't look too bad...
03-16-2013, 05:07 PM | #5 |
Bump.... Anyone install this sensor kit???? Wideband A/F Ratio kit....
03-16-2013, 07:07 PM | #6 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
These cars do not have a wideband O2 installed from the factory. You need to install an aftermarket one in the exhaust, then you can run it to the gauge.
03-16-2013, 07:09 PM | #7 |
Drives: ZL1 Convertible Join Date: Aug 2012
You know, there are two ways to read the title to this thread. I'm just sayin'
06-15-2019, 10:57 AM | #8 |
Drives: 2015 ZL1 Join Date: May 2015
i know this is an old thread but on a 2015 ZL1 how do you get the guage to
shut off? mine powers up with the key off, or is it a delayed shut off?? |
06-15-2019, 06:48 PM | #9 |
Drives: 2013 camaro zl1 aka the Reaper Join Date: Apr 2018
anyone running the dual gauge defrost vent mount? need to know how much room ill have between the cage and gauge
06-16-2019, 10:10 AM | #10 |
[QUOTE=fluxzl1;10545292]i know this is an old thread but on a 2015 ZL1 how do you get the guage to
shut off? mine powers up with the key off, or is it a delayed shut off??[/QUOT I have the Aeroforce gauge. I didn’t have to hookup the air/fuel because I already have a wideband with single pod on my steering column. I used the single defrost vent pod for the aeroforce. It will power down on its own. |
