09-08-2012, 09:58 PM | #1 |
Methanol
Where is a good place to get methanol? Is there any other products that mimic this?
09-08-2012, 10:05 PM | #2 |
Drives: 2010 Camaro Auto 2SS/RS Join Date: Oct 2008
Any performance shop should be able to sell it too you. Heard from someone that windshield washer fluid could work in an emergency. Me personally though...I won't touch the stuff. None of the systems are reliable enough imho and if they go...so does your engine. Not to say there aren't a ton of people out there running it with no problem. I just won't take that risk.
Built by Jannetty Racing
670rwhp/649rwtq...Scariness to be determined. Jannety Racing forged 416. TVS2300 Supercharger w/Maggie Max Stage 2, 3.6 Pulley, Innovators West 8 rib conversion, OD rear Cog belt drive. Jannetty Racing Rough Idle Cam, LS3 Conversion. Jannetty Racing built 6l80e Trans, Jannetty Racing Custom Converter, Built rear diff w/ 3.45 gears, DSS driveshaft and 1400 hp axles. ADM Twin Pump Fuel System, ADM CAI, Dynatech 1 7/8" Coated Headers, Borla "S" Catback. Custom 18" Forgestar F14's, Nitto 305/45-18 DR's |
09-08-2012, 10:07 PM | #3 | |
Drives: 2010 Camaro Join Date: Feb 2010
• Snow Performance sells 51/49 water/methanol mix as Boost Juice™ (see products). If this is used exclusively, Snow Performance can lifetime warranty a system so long as the free registration card is sent in soon after purchase. • Methanol can generally be purchased where racing fuels are sold. Also, most gas line dryers like "Heet" are simply methanol. Suppliers of industrial chemicals can also supply methanol for a very reasonable price. Ensure that the methanol is "neat" and therefore has no additives or lubricants added by the supplier. • -20 degree F rated, blue windshield washer fluid is acceptable for use as well, and is available at most service stations. Although some fluids rated to under -20 degrees F contain glycol and other copolymers, most windshield washer fluids are up to 40% methanol. Try to find one that displays "contains methanol" on the label and is good to -20 degrees F, with no additives or special ingredients and is blue in color. • Methanol can be purchased on the web at www.worldwideracingfuels.com and www.hiperfuels.com. • Additionally, many sprint car drivers and circle track and drag racers use methanol as a primary fuel. They often have methanol on hand and will even sell methanol that has been un-sealed for a long time at a very low price. Just be sure that the methanol has NO additives or lubricants (such as top lube), as they are not needed and can damage the pump. |
09-09-2012, 12:42 AM | #4 | |
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60' Join Date: Jul 2009
09-09-2012, 02:46 AM | #5 |
Funny you posted that after a guy that had a costly meth failure lol. I'm not an expert by any means, but from experience and what I've been told by people that do this for a living...meth is not the way to go. Just adding meth with no tuning does nothing (from what I understand). Tuning for extra power, because of meth, puts you in the danger zone if it fails. To me...that's not a product I would want in my car. If I want more power, I will use race gas and increase the boost.
09-09-2012, 08:02 AM | #6 | |
Drives: 2018 camaro ss 1LE Join Date: Aug 2011
Winshield washer Pacer -35!!!50/50 water-meth!!!that's what I used in my celica at 100% of the time!! My 2000 celica = 1.8 with a Garrett gt3076r@24psi 543whp
2018 CAMARO SS 1LE
2011 CORVETTE GRAND SPORT SOLD 2007 CORVETTE Z06 Sold SOLD 2010 CAMARO 2ss m6 SOLD --magnaflow comp exhaust--cai (cold air inductions)--JRE Scoop, Roto-fab bottle--SP 1-7/8 LT Headers--SCT itsx with 415 Ted Jannetty tune--1le 3.91 gears--rx catch cans-- 12.9@113.8mph |
09-09-2012, 08:13 AM | #7 | |
Drives: 2011 Blue1SSRS 623RWHP, 02 vette Join Date: Aug 2010
Just have not added it to the car yet used for Go carts.and other race applications...
2002 Vette (stock)
Team LS-3 |
09-09-2012, 08:29 AM | #8 | |
Drives: it changes Join Date: Nov 2010
For a foolproof setup and if your ecu allows it, AEM offer a flow meter with a 0-5v output which can be used to apply any fuel/timing adjustments IAT is another option, but it does make a lot of assumptions and isnt the best way to do it. But it can work. And race gas isnt practical for a road car. Fine when racing though |
09-09-2012, 09:43 AM | #9 |
Get an alky Control kit from julio and be done with it... Lots of saftey features to let you know if anything would ever happen..
09-09-2012, 11:10 AM | #10 | |
Also, a fuel pump can fail just as easy causing motor failure. As long as its fully understood, there is nothing wrong with using methanol |
09-09-2012, 11:12 AM | #11 |
Black10.. Some I'm clear on this.. If I have a tank that is empty is there any chance in boost to hurt engine.. Or is it in boost methanol runs out then there's issues.. Can you clarify..
09-09-2012, 11:12 AM | #12 | |
09-09-2012, 11:15 AM | #13 |
The most dangerous time would be during boost if the meth fails, but if properly tuned, the safties should prevent damage .
09-09-2012, 11:19 AM | #14 |
yes if u are tuned for meth u need to make sure it does not go empty!! if it does dont go in boost!
