Old 01-26-2014, 06:14 AM   #1
Leb SS2/RS
Leb SS2/RS's Avatar
Drives: 2011 Camaro SS2/RS
ACS T3 Eagle light installation help
Hey guys,
I bought the ACS front port T3 a while ago, it's been installed since then, but I have the eagle triple light kit with it, but I can't find a way to hook it up to get it to work. I went to electric shops here, they told me the kit is missing a harness or like a board to control the light voltage and so on...
Can any one help out please
Leb SS2/RS is offline   Reply With Quote
Old 01-26-2014, 07:35 AM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Can you post the wires you have? they all go one to the other and then the last one ( per side) goes in to the car wires.
Old 01-27-2014, 01:40 PM   #3
Chris82xx
Make your peace with God!
Chris82xx's Avatar
Drives: 2011 Camaro SS/RS M6 Convertible
Originally Posted by Leb SS2/RS View Post
Hey guys,
They take place of the where the OEM fog lights plugged in. The connector looks different, but ACS provides the pieces to make the male portion of the harness. You have to completely cut off the entire OEM harness pug, strip the wires and put everything together.
ECS base supercharger (NOVI 1500SL), ECS AlKY control kit, 92mm TB, ARH 1 7/8" LT's non-catted, Borla 3" exhaust, ID850 injectors, Squash fuel system, ECS Big Blower Cam, MGW short throw shifter, DSS 1000hp axles, LGW differential cover, billet caps, Tech AFX heater hoses, Pedders differential bushings, Eaton TrueTrac differential, PRC dual valve springs, Katech C5R timing chain, ATI balancer, Meilings oil pump, Pfadt Trailing Arms, Pfadt Tie Rods, Pfadt Sway Bars, Pfadt End Links, DSS Aluminum Driveshaft
811RWHP/719RWTQ
UNDER MAJOR OVERHAUL!!
Chris82xx is offline   Reply With Quote
Old 01-27-2014, 02:51 PM   #4
SIM Curly
SIM Curly's Avatar
Drives: Silver 1LT 2011 camaro
I just went to the existing harness
SIM Curly is offline   Reply With Quote
Old 01-27-2014, 06:34 PM   #5
montreal2010yellow
montreal2010yellow's Avatar
Send an email to ACS they know the solution. Mine are working good.
Name:  camaro facia Eagle lights on.jpg
Old 01-28-2014, 07:20 PM   #6
Leb SS2/RS
Leb SS2/RS's Avatar
Okay guys thank you!!! I thought about it and it seemed logical, but the shops over here kept saying something about an aftermarket harness for LEDs and voltage... Bla bla bla
Now I can hook it up and enjoy!
If by any chance I lost the male adapter from ACS to hook up to lights, could I get replacements from any electric shop, or only ACS ??
Thanks again guys!
Old 01-28-2014, 07:22 PM   #7
Leb SS2/RS
Leb SS2/RS's Avatar
Ohh and btw montrealyelloww... Car looks stunning with the bumper and lights combo!! Looks greatt!
Old 01-28-2014, 08:19 PM   #8
USMCSSGT-RET
USMCSSGT-RET's Avatar
Drives: '14 SIM 2LT/RS Vert
Should be plug and play from the factory harness to the harness that comes with the new lights.
USMCSSGT-RET is offline   Reply With Quote
Old 01-29-2014, 02:53 AM   #9
CamaroI
Drives: 2010 IOM Camaro
wait till only one pod light goes out :>) glad I got rid of mine
CamaroI is offline   Reply With Quote
